Good morning!!!!
   / Good morning!!!! #25,111
Gloomy day here but sun did come out for a bit. Another day lost to rain no way to make them up now except Saturday's and really do not like working those. Did go look at two new jobs then some inside chores. Dinner time will be here soon
   / Good morning!!!! #25,112
Morning (just barely) Y'all!
I got a nice PM checking in to see if I was still alive and I am happy to report I have not been selected for duty pushing up Daiseys yet...
I was shocked to see #1 I was 500 posts behind on this thread (I just spent an hour skimming to catch up a bit) and #2 that it had been 8 days since I last posted. JD Green would say I've become a slacker as a post-*****...
My life is mostly unchanged. I'm trying to b!tch less and be happy more, I've been busy with the job search and some minor projects. My right elbow, bicep and shoulder are still VERY sore from limbing with a 20" FarmBoss like 3 weeks ago... might be tennis elbow, not sure...
I'm hosting a birthday bonfire party for a very good friend this coming Saturday and the big pile is not really finished because I can't saw right now (and not for the last 3 weekends either)... But the little pile is ready to rock.
I will try not to be a stranger, I really appreciate my TBN brothers and the supportive environment here.
Be well & God Bless all of you,
David
As the body ages it takes longer and longer to heal. What I used to get over in a few weeks (say a pulled muscle) now takes a month or two and I keep aggravating it until SWMBO forces me into Lazy Boy rest.
Looking forward to more pics!
Drew - did you suggest to them to leave the equipment and keys over the weekend? My Father did that and used the bulldozer to turn a 1/4 acre pond 8' deep into a 1 acre pond 14' deep :)
   / Good morning!!!! #25,113
you know....I've been looking at the controls on that grader...naaah. :D
I'll go back and look at the original spec; I know it's a lot of underlayment material.
16 tons of base material
933 SY of prep base and finegrade (what is SY??)
pave with 2" of SF 9.5A
   / Good morning!!!! #25,114
The driver is pretty good at tailgate spreading, like the way he used the side boards to keep stone out of your yard. Smart and talented
   / Good morning!!!! #25,115
68F and partly cloudy @ 21:30 ...
Enjoying my first cup of coffee and trying to wake up ... I slept like a log ...
The report is that the front lawn - which is probably 80% of it - has been mowed. I might be able to get the area around the house done with the Simplicity in the morning ... if the rain holds off long enough. More and more leaves are starting to fall ...
I've been tasked with the taking the trash out on my way up to the shop (tomorrow is trash day) ... which is somewhat unusual - normally it doesn't get put out until the morning, due to the 'coons.
I got the 2nd arm for the upper jaw welded up yesterday before I knocked off ... have some grinding to do on that, and then should be able to get the arms tacked onto the pipe that holds the upper jaw teeth ... and get the other cross pipes tacked on as well ... so the upper jaw will be mostly assembled/put together, except for the pin mounts - which won't get tacked up until the lower section is welded up ... so that the hinge pins can be inserted into both pieces for alignment.
Also got the lower rake teeth ground with bevels ... so those are ready to be tacked up too. Have to be careful doing those ... the chisels on the tips are extremely sharp ... accidently bumped my hand into one of those yesterday and had blood squirting all over.
Need to do something with hinge/pivot points for the upper jaw, as far as being able to grease them. It's either drill and tap the D.O.M. tube that serves as the pin mounts, or drill and tap the pins themselves. I think drilling and tapping the D.O.M tube will probably be easier, in terms of accuracy, with the equipment I have available. If I had a lathe or a mill, drilling the pins (accurately) would be more realistic. Easy decision.
Hope everyone had a good day.
   / Good morning!!!!
Interesting day here, I went and looked at a old building with a bil. He has been in the restaurant biz for many years, and is buying this building and restoring it. Met with a architect and the building official. All things I've not been exposed to before. I am going to help him remodel this place over the next year. Maybe I'll need some more tools (toys?).? :)
   / Good morning!!!! #25,117
Aww now c'mon ... where's that TBN "can do" spirit ?
Probably square yards (at a particular depth)
   / Good morning!!!!
Welcome back, David. Hope things get better for you.
   / Good morning!!!! #25,119
Absolutely ... :thumbsup:
Start the acquisition list now ... so you have plenty of time for proper contemplation ... ;)
   / Good morning!!!! #25,120
Failed to get Scag running :(
Both starter and solenoid checked out OK. Cleaned connections and installed new battery. Still just get clicking sound. Need more research
Started current round of mowing with flail.
Sent from my iPhone using TractorByNet
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A52128)
Rhino FS15...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
John Deere 455G Loader (A48837)
John Deere 455G...
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
