Allied cylinder - rebuild or replace?
/ Allied cylinder - rebuild or replace? #1
bauer5
Kingston, ON
Massey 50
This cylinder came off an old allied loader. It is leaking miserably from the top end and I need your help determining whether it's worth the effort to rebuild it or just replace it for $150. I have attached some pictures that show the worn end, and it appears to be just a rubber gasket, no locking mechanism in view. First time dealing with a hydraulic repair so any help is appreciated.
/ Allied cylinder - rebuild or replace? #2
At $150 if it is an exact match I would go that route.
That being said a good shop can OH just about any cylinder to like new.
Generally it is hard to get an exact match leaving U no choice.
Your shaft looks good so I'd suggest OH should be cheapest route to go as probably you only need a seal kit and wipers.
/ Allied cylinder - rebuild or replace? #3
I had an Allied 660 on my tractor. The ends of the cylinders closest to where the chrome rod extends would unscrew using a pipe wrench. You could buy seal kits from a dealer who sells Allied but they were expensive. You might get lucky matching at a hydraulic shop. Most of the internal seals were O rings with nylon wipers on either side of them. The one seal which failed often was a small o ring between the push rod piston and the push rod. You had to unscrew a big nut to get to it. When it failed the cylinder would not stay in position. It was the cheapest seal to replace costing only a few cents. The seal kits were about $16 per cylinder
The following diagram is for a 3" cylinder which was used on tractors with low hydraulic pressure but the way it is built is the same as yours.
Dave M7040
Dave M7040[/QUO
Ok thanks. I still don't understand how the cylinder is taken apart though as it seems like there should be a retaining lock ring or something similar. Are you saying that turning the rod would unscrew it?
/ Allied cylinder - rebuild or replace? #5
Item 12 is your retainer.
Remove it and then unscrew the head plate item 9.
I don't see a head plate - is it under the wiper?
/ Allied cylinder - rebuild or replace? #7
I believe the head plate is the part that screws out. item #9.
/ Allied cylinder - rebuild or replace? #8
I think the head plate(part key 9) is held in place by only the snap ring(parts key 14) no screwing required to disassemble.
Ok I will try that, thanks guys!
/ Allied cylinder - rebuild or replace? #10
If you are looking at the cyl layout above,
Part key 14 is an o-ring. It is down inside the cyl.
Part key 12 is the snap ring/wire retainer. Whether is screws out or just falls out is ???????????
/ Allied cylinder - rebuild or replace? #11
J-J
Thanks for correcting me as I meant parts key 12 was the snap ring. On cyl schematics I've seen if there where threads they would be depicted in schematics but I'm unfamiliar with Allied. I see no need for both threads and a snap ring BUT who knows.
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
2005 Amadas 2100 (A64126)
2005 Amadas 2100...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
Rolling Shop Table (A64127)
Rolling Shop Table...
2016 Chevrolet Silverado 3500 Auto Crane Service Crane Truck (A64194)
2016 Chevrolet...
