Good morning!!!!
   / Good morning!!!! #24,891
Drinking first cup of coffee. 40° with clear skies this morning. Heading to 71° with lots of sun all day. Looks like a stretch of nice fall weather heading this way. Lawn needs cutting again. But not the heavy stuff growth that has been going this year.
Good Morning All.
   / Good morning!!!! #24,892
50 this morning high of 69 later. The weather people can not make up their minds if it's going to rain later in the week. Good Morning
   / Good morning!!!! #24,893
40F upper 60's for high not a cloud in the sky for the first day of autumn.
Winds finally die down,gusty last evening which loosen some leaves from tree also those darn pine cones.
Enjoy the day all.
   / Good morning!!!! #24,894
those darned pine cones are dropping on my place too...
what can you use them for; anything worthwhile?
If I dig a hole and put a pine cone in it, will I get a tree?
   / Good morning!!!! #24,895
RS, I remembered something interesting....as I have readily admitted, my knowledge of welding is only from a book, a How To book, actually a good one, I have kept in the usual reading spot, in the bathroom next to the Northern Tools catalog.
And i remember reading in there of a warning that went something like: "be careful that welding does not bend or distort the underlying piece, particularly if not secured properly".
Well, it was worded better than that, but your picture could be an illustration in that book.
Yup ... it's a text book example.
Funny thing is, it just wasn't all that noticeable ... until I sat it's mate on top of it in the opposite direction ...
Shoot Uncle Buck even missed it ... he was down tonight and I showed him the picture of one beam laying on top of the other and he was very surprised - not that it bent ... but at the amount of warp and that it wasn't more obvious.
I admit to being a little hesitant starting to weld, as that book plus many YouTube instruction videos have basically shown me how very very easy it is to screw up. Oh dear, my pool is not advancing properly...:D
Need to find some scrap steel to practice on.
LOL ... start looking for a fab shop honey hole that will let you dumpster dive in their roll-off of drops ...
Here's the thing tho': while it may be easy to screw up, it can often be easy to fix. An example:
Last night I was getting all frisky and decided to start welding up the arms for the upper jaw ... one of the pieces had already had a bevel put on it so I grabbed the other piece that was going to be welded to it and ground a couple of bevels in that and then clamped them down to the table and put in the root and cover passes ...
Then later after Buck left I got looking at it ... aww crap ! ... I had welded it together with the one piece 180 degrees out of correct orientation.
Luckily I had only welded one side. Slap a zip disc in the grinder, cut em apart, grind the bevels on the correct side this time, clamp it down and weld it up. Took me probably 15 minutes or so to fix my screwup ...
I still have to weld where I ground the bevel in the wrong place and then grind that off to put it back to the original shape ... but once I do it won't be all that noticeable, if at all. Another 5 minutes and a little wire and gas.
To my delight the prior owner had already run a 220 line to the workshop in the barn, but I'm not sure it will carry enough amps for the welder. I think it needs 37 amps at max.
Mines on a 50A breaker ... Lincoln recommends a 60A if I recall correctly ... but I don't think I've ever tripped it (I'm only using .035 wire) I think the max draw on input is maybe 40 some amps ...
The power pole is thirty feet away with a transformer on it, so not like it will be hard to get more juice into that location.
Easy-peasy ... ;)
I'm sitting out at the end of a 400' run of I think single aught (0) aluminum from the house ... :(
Power company would love me to spin that meter until it overheats.
No doubt ...
Maybe I'll get one of those old time oiling cups for the meter so as I go by I can give it a shot of oil once in awhile...;)
I can loan you Grandpa's ... :D
   / Good morning!!!! #24,896
Morning all, 44F here now but heading to 70F this afternoon. Making headway on the unpacking, put up shelves in laundry room, so now I have a place to put all the stuff.:thumbsup:
   / Good morning!!!! #24,897
Goooood Morning TBN!.
Cool morning today. 67 degrees under clear blue skies. The humidity has cleared out. Sun just coming up. Projected high is 87. Perfect day.
   / Good morning!!!! #24,898
45 right now. Headed to 76 today. Got mowing done yesterday. Still have trimming to do. Off to town for lab work. Fun fun.
Drew, if it's a flat ceiling there isn't much hope to stay dry. Other than to wash in two or three passes so as to not spray where you are standing. If it's sloped then you can do pretty good by remembering water run down hill. Also on day I am going to get wet I try to wait till 9 or 10 to start so it can warm up some.
   / Good morning!!!! #24,899
44 and sunny,looks like a nice day with a high of 73 Today.We are going shopping Today.
   / Good morning!!!! #24,900
Good Morning. 0920, overcast, 73F with 82% humidity. Forecast high of 82F with 10% chance of rain this afternoon, and a low of 63F tonight.
Today is the 1st day of fall, and we are finally getting some cool temps. Sure feels nice out.
I'm off to Payne & Payne this morning to have a cavity filled. Do you think maybe I could find a worse named dentist? It's a father and son practice, and I see the younger fellow. I do like them, and you never have to wait.
Hope everyone is having a good day.
Larro
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
Terms and Conditions (A47384)
Terms and...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
