Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,711
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I did a Lucas CAV throttle and kill shaft seal repair today.
When I got it all cleaned up I could see the linkage was really worn.
Taking off the linkage Layer by Layer
The short end of the spring was somehow lodged in a solid place but on reassembly I can't get it to catch anywhere. I think it goes in the clockwise groove on the lower linkage piece. I am not sure how this is supposed to work but it appears to me the two levers with the spring connection allow the operator throttle control to over travel. Maybe to insure consistant idle and WOT position at the pump ???
Anyway, I am looking for a place to buy replacement parts, especially the spring, or an idea on how to lengthen the spring post. I am afraid to bend it in fear that it will snap.
I also broke a bleeder screw and would like to replace the cap and bleeder assembly w/ copper washer.
The open heart surgery went fine. It is just this linkage I need to fix. Thanks for any help.
If you never saw one inside here it is. New gasket and ready to reassemble.
