Mowing 2615 pto stopped
/ 2615 pto stopped
My splines are showing I can slide shift back in cupler .so is there a technique to keep in in cupler? Also if I for need kit where do I split it and I guess I don't remove top where arms that raise attachments are .Thank you in advance .
/ 2615 pto stopped #22
The coupler has an internal retainer clip. If it is sliding back and forth, you have not pulled the coupler and shaft together enough. It will clip in place. Push the shaft rearward into the coupler. If you need to split the tractor I'm not going to be able to detail out the steps for you in this forum. But you do not need to take off the rockshaft housing.
/ 2615 pto stopped
Well thank you for all your help I see inside oil fill hole the shaft and it has split from other side so I'm guessing I need to split tractor at clutch housing just in front of the oil fill housing so I can push shaft together? Thanks again
/ 2615 pto stopped
Also is this the shaft that pulled into/seperated#19631241001?
/ 2615 pto stopped #25
pw42, now that I have you on the right track, visit your local dealer and ask about the kit that solves this issue. You can just split it but the shaft might walk out again. Get your parts kit and ask him if he can give you a few tips on how it comes apart and goes together. It's not all that complicated, but it has to be split at the bell housing and then once again I think at the next casing. Might as well put the new improved parts in it. Good for you for being willing to tackle a project like this.
If you are just going to stick it back together with no new parts, then I'd scratch my head for a while and see if you can make a custom set of pliers to grab the shaft through the hole to push it back in place. I never went that route as we replaced with the new parts. But I'd think it may be possible to pull this off.
/ 2615 pto stopped
Called local dealer that's why I'm on forum he didn't know and has yet to call me back about price for new shaft. His mechanic has never worked on this pto.
/ 2615 pto stopped #27
I always try to push business to the local dealer. Our parts department can get you the parts if your local guy can't figure it out. If he calls the service rep they should know about it, or even the parts rep and then he could order it for you. I'd prefer that. They did not fail often and if your dealer did not sell a bunch of this model he has probably never seen the problem.
I think the part is the shaft, coupler and clip.
/ 2615 pto stopped
OK I hope I split this tractor in the right place so I can remove all the bad parts.
/ 2615 pto stopped #29
Let's just hope this job doesn't give you a splitting headache. If I had to do this on my own, I'd definitely pick up a repair manual.
/ 2615 pto stopped #30
i'd for sure want an exploded diagram at a MINIMUM!
/ 2615 pto stopped
20140922_125711.jpggot it apart but second half at bell housing dosent want to seperate?
/ 2615 pto stopped #32
Got to hand it to you. Don't know i would attempt this. Keep us advised!
/ 2615 pto stopped
She's working !! Thanks for all the help!!!
/ 2615 pto stopped
With a 3/4 pipe cut in half run along shaft through access under seat and tap coupler forward until it stop .
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
FORD 2810 TRACTOR (A64277)
FORD 2810 TRACTOR...
Caterpillar D6N XL Crawler Dozer (A65579)
Caterpillar D6N XL...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
Land Hero Mini Skid Loader (A66408)
Land Hero Mini...
