Front snow plow/rear remotes
/ Front snow plow/rear remotes #1
Ole Orange
Ripley, Maine
L3650 DT GST & LA650A FEL
While I am trying to figure out a problem with my trailer in another post I am looking towards winter with the tractor.
I have a 8 ft fisher flow I am mounting on the front of my Kubota tractor. it has 2 rams with only 1 port per ram. What I want to do is run my two hoses from my rear remotes up to these 2 rams. 1 hose per ram, my rear remote control has a forward motion and rear motion with center stop. does any one know if this will work for these 1 port rams. I really do not know much about hydraulics, but have this set up and it would be great to angle my plow as on my old one I had to get out and do a manual angle with a bolt that drops in, no rams.
Thanks for any info you might have.:)
/ Front snow plow/rear remotes #2
works great on mine
/ Front snow plow/rear remotes #4
It should work just fine using one remote with one hose going to each outlet on that single remote - when you apply pressure to one hose the other acts as the return with no pressure and vise versa .
