Blind bolt options?
/ Blind bolt options? #21
How much extra cover flange does the grab handle have? Is there enough cover to shift it over and drill new holes and install 2 new inserts, even if you had to order closest SAE size to the current metric that is there?
/ Blind bolt options? #23
What about a huck bolt, joe bolt, or even a stainless steel blind rivet. These bolts I mentions have an allen head recess on the front you hold and tighten the head. This causes the tail to swell and cinch up. The stainless versions are pretty strong.
There are quite a few blind fasteners to choose from. Grainger or Mcmaster Carr have good selections.
/ Blind bolt options? #24
/ Blind bolt options? #25
I would ask a body shop. They probably know of a cheap & simple fix.
/ Blind bolt options? #26
Rivnuts are an aviation device and pretty well the same as wellnuts.
While I have a set of tools to install them you can do 'one of's' with a suitable machine screw and proper spanner.
The main requirement is that the drilled hole be the exact size of the insert. As the name implies they are inserted blind rivets. The area between the threads and the flange are thinner walled and collapse to form a rivet when torqued up tight.
I would however try to insert a star washer under the flange between flange and hole face to prevent the insert from spinning once squeezed into place.
/ Blind bolt options? #27
McMaster-Carr
McMaster-Carr has both metric and imperial.
You can buy one or a million shipped right to your door.
I usually get stuff the next day if ordered before 2pm,
but that depends on how far you are from their nearest
warehouse of course.
/ Blind bolt options? #28
Surprisingly home depot has a pretty good selection of blind fasteners for furniture.
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
3145 (A63117)
3145 (A63117)
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
2018 Chevrolet Impala Sedan (A64557)
2018 Chevrolet...
