Echo SRM225: runs butt dies when applying throttle
/ Echo SRM225: runs butt dies when applying throttle #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I had a friend give me his 1 year old 225; as the title says it dies when you advance the throttle. I do not have experience repairing weedeaters but I'd like to fix it if I can. I ran it, and you can depress the throttle all the way in choke, and the engine accelerates a bit, but bogs down. Move out of chock and if you depress very slowly, you once again get a little acceleration but the engine will soon die. I took off the carb, looked at the jet and the condition overall - it wasn't really dirty. Thought I'd ask for some troubleshooting help... looks like you can get a carb rebuilt kit easy enough but I don't want to order what I might not need! Thanks.
/ Echo SRM225: runs butt dies when applying throttle #2
Go over all fuel lines and check fuel pickup/filter. Make sure air cleaner is OK.
If no obvious issues, I'd try adjusting the low speed screw richer and see if that helps throttle response. Then maybe tweak the high speed screw the same way (can richen until it warbles / 4-strokes at full throttle and then back off a teeny bit).
But if this condition came on randomly, then it's most likely he left ethanol gas in the carb too long and something got messed up. In that case, rebuilding or replacing the carb is probably the best bet. A rebuild kit should be cheap, but definitely look over the carb body well to make sure there's no signs of blockage/damage. In some cases, even running the carb through an ultrasonic cleaner can't rescue it, so it has to be replaced.
Echo makes a very good quality unit, so it's worth fixing for sure.
/ Echo SRM225: runs butt dies when applying throttle #3
What S219 said.
When I've had to, I've replaced float valves/seats that were really crudded up.... but I prefer to not tear into carbs if I can avoid it...
1) If you haven't already, check the sparkplug. With bad gas, or a really heavy oil mix, even a plug that "young" may be an issue.
2) Try some Seafoam (added to gas, not pure). Run this mix as best you can to get it to circulate, then let it sit overnight. Try again.
Rgds, D.
/ Echo SRM225: runs butt dies when applying throttle #4
Did you allow it to warm up at idle for a long enough period of time ?
These newer lean burning trimmers do take a much longer time to warm up than old trimmers did.
My 2 year old echo trimmer does the same thing as your trimmer when it's first started, and needs to sit and idle awhile (at least 3 or 4 minutes) before it will not hesitate when I advance the throttle.
My 3 year old Echo chainsaw acts the same way.
Once I get past these long warm ups, they preform really great.
My 10 year old husqvarna trimmer only requires maybe a 1 minute or less to warm up, before I can advance the throttle with out hesitation.
My 12 year old husqvarna chainsaw act like my old Husqvarna trimmer on warm up.
Another thing that might contribute to this hesitation issue, these Echo trimmers usually require at least 89 octane or high gasoline. The 87 octane may work, but the trimmer will start easier and run better on at least 89 octane.
/ Echo SRM225: runs butt dies when applying throttle #5
Besides advise given above ,make sure you put your fuel lines on correctly and not reverse them. If they are put on backwards unit will start and cut off after about 20 to 30 seconds. Don't ask me how I know ! :D
/ Echo SRM225: runs butt dies when applying throttle #6
That's a nice looking trimmer. So if the tank, filter, lines & primer bulb look ok with no cracks, etc. (good point about reversing the fuel lines, done that myself when replacing them), it would seem your carb high-speed circuit might be the culprit. Backing out the high needle valve doesn't help? I think I'd disassemble the carb & clean all the passages with carb cleaner. Keep the cleaner out of the primer bulb circuit, as it will swell the little plastic check valve (caveat - at least on my stihl edger). A year old, you can likely get the carb apart without ripping the diaphram or gaskets. Among other things, blow carb cleaner through it, check that the main jet spews cleaner. Wear eye protection! Carb cleaner is nasty stuff. Pix or an exploded view are good to get the diaphrams & gaskets back on in the right order.
The product website is here.. Would the 5-year consumer warranty help you out here?
/ Echo SRM225: runs butt dies when applying throttle #7
DHD makes a good point about warming up, to which I should add that my carb diagnostic/adjustment advice up above assumes a warmed up engine. Don't make the mistake of tuning the carb on a cold engine, since it will later run richer when it warms up!
Thanks for the input. Spark plug looked rough. Filed it a bit and she ran pretty good at full throttle. Got a new plug, fresh ethanol free gas + seafoam. Ran it for 5 minutes, then the behavior started up again. Depressing the trigger stalls it out. I should prob. get a carb kit; they are cheap enough. It all looked clean when I took it apart earlier though.
/ Echo SRM225: runs butt dies when applying throttle #9
Keep running sea foam thru it. it will clear up.
/ Echo SRM225: runs butt dies when applying throttle #10
Sounds like a collapsed fuel line. Fuel line might look fine when it is not running but collapsing when it is running.
/ Echo SRM225: runs butt dies when applying throttle #11
Try cleaning the muffler. I have an echo that had the same symptoms as yours. I removed the muffler and saw it was clogged with oil and carbon. I used carb cleaner to remove the gunk and deleted the spark arrestor screen entirely. Ran like a champ after that.
Sent from my iPad using TractorByNet
/ Echo SRM225: runs butt dies when applying throttle #12
I had that clogged muffler issue on my Husqvarna trimmer once, and it had that slow to accelerate problem.
Turns out I was using too much oil in my oil gasoline mix and I also was not running my trimmer at the full operating speed.
/ Echo SRM225: runs butt dies when applying throttle #13
I had that clogged muffler issue on my Husqvarna trimmer once, and it had that slow to accelerate problem. Turns out I was using too much oil in my oil gasoline mix and I also was not running my trimmer at the full operating speed.
I switched to synthetic oil mix and haven't had a problem since.
/ Echo SRM225: runs butt dies when applying throttle #14
I was using synthetic oil at the time and still do now.
I was just making my oil/gas mixtures more 1 to 40 rather than 1 to 50 per recommendations of an old
retired chain saw mechanic.
Coupled with extended periods of not running at full throttle.
Since mixing oil/gas at 1 to 50 and running full throttle, I have note had any issues.
/ Echo SRM225: runs butt dies when applying throttle #15
My 230 was doing that and I bought one of those kits with all the hoses, rubber plug, and fuel filter. I then bought that premix in a can (no ethanol).
Runs like new. It's 12 yrs old.
/ Echo SRM225: runs butt dies when applying throttle #16
I have a very old echo that was a hand me down. Ha same problem, but after cleaning air filter it runs fine.
My 230 was doing that and I bought one of those kits with all the hoses, rubber plug, and fuel filter. I then bought that premix in a can (no ethanol). Runs like new. It's 12 yrs old.
Interesting. Can you point me in the direction of the kit you used?
I ran it again last night, just let it idle a bit. It runs a little rough, then all of a sudden stronger, putting out a little smoke - at that point I can give it full throttle - but it dies soon afterwards.
/ Echo SRM225: runs butt dies when applying throttle #19
I have an older Ryobi trimmer and I was having a similar issue. It would run great with the choke full closed, but when I opened the choke, it would die when I squeezed the throttle. Turns out that the gas tank fuel line had degraded so badly that it was no longer using the filter at the end of the line. It was pulling fuel in thru the gas line mainly without the filter in play. Replaced the line and re-attached the fuel filter and back to normal again. Just a thought.
New/Unused CFG Industrial MH12RX Mini Excavator (A65579)
New/Unused CFG...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
2018 Ford Fusion Hybrid Sedan (A64557)
2018 Ford Fusion...
