Welding extension question 110v
/ Welding extension question 110v #11
Harbor Freight has a sale on their gensets now. It wouldn't take much generator to run a 110v welder on a 20 amp circuit, 3000 watt should do fine and would be within your budget.
/ Welding extension question 110v #12
i won't comment onthe suitability of THHN cable for your application.. however it's insulation appears rated at 600v from what i can find. Not sure what specs of the specific cable you ae intending to use though.
ok single set of conductors drops me 6.19v down to 113v do-able? Also the generator .. 3000 watts will do you think?
/ Welding extension question 110v #16
Lets see how this looks with 20 amp load and 155 feet one way distance:
Result
Voltage drop: 6.19
Voltage drop percentage: 5.16%
Voltage at the end: 113.81
OK this above is for No. 10 wire. Hot/black Neutral/white and Ground/bare
Now lets look at running 2 sets of No. 12 wire in parallel. So two black's together two white's together and two grounds together.
Result
Voltage drop: 4.92
Voltage drop percentage: 4.10%
Voltage at the end: 115.08
Please note that the result is an estimation based on normal condition. The actual voltage drop can vary depend on the condition of the wire, the conduit being used, the temperature, the connector, the frequency etc. But, in most cases, it will be very close.
So it looks to me you would be a bit better off to run 2 sets of No. 12 wires in parallel than the single No. 10 set.
/ Welding extension question 110v #17
Here is what you do, find the center of your 310 foot of No. 12 wire and carefully open up the insulation, and carefully wrap your no. 12 wires as a loop around the plug screws. Then put an outlet box on the welder end, and you will be able to wrap under both sets of screws of a normal outlet in your box. Now you have a 155 foot extension cord, that will handle your load pretty well.
/ Welding extension question 110v #18
Look at good quality used generators. Obtainable for a few hundred.
/ Welding extension question 110v #19
is this the point in the thread where it's ok to bring up a pto genset to keep it tractor related?
Ok.i just read the conclusion of 2x 12-2 romex would be better. Then could've used it after the job to wire the stalls. Anyway, got in my car earlier to pick up some wire.sat there . Read some more replies about generators and looked on Craig's. Found one (UST (5500W) for $350. Got down to $250. Went down there wouldn't start. Gave him 200. Got it home and it purrs and powers the welder. Thank you guys for the insights and knowledge. You rock. image-1101412869.jpg
1990 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1990 Lufkin...
2024 JCB 35Z (A60462)
20FT X 12FT LIVESTOCK METAL SHED (A58214)
20FT X 12FT...
2018 Ford F-250 Service Truck, VIN # 1FD7X2A60JEB74871 (A61165)
2018 Ford F-250...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
