JD112
/ JD112 #1
denny 423
Williamsburg, OHIO
jd112
1974 MODEL 112 runs fine for about 15 minutes then acts like it runs out of gas let it sit for about a minute or two starts back up in a run for about another 20 minutes can anybody help me.
/ JD112 #2
Hiya,
Most likely a plugged fuel tank vent. I believe the vent is in the cap on these models. When it dies again, open the hood and slowly take the cap off while you listen for the sound of air getting sucked into the tank, if you hear air going in as the cap breaks the seal, you have found your issue. Either clean the vent or get a replacement cap.
Tom
/ JD112
Hiya,
Most likely a plugged fuel tank vent. I believe the vent is in the cap on these models. Whe let it sit about a minute and restartedood and slowly take the cap off while you listen for the sound of air getting sucked into the tank, if you hear air going in as the cap breaks the seal, you have found your issue. Either clean the vent or get a replacement cap.
Tom
that's what I thought too second time I left the cap loose and start mowing again in about 10 to 15 minutes it quit again but it said about a minute
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2022 Husqvarna Z560L Zero Turn (A63116)
2022 Husqvarna...
2017 Unverferth 1245R-35 Rolling Harrow (A63116)
2017 Unverferth...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
2014 HYUNDAI 53X102 T/A DRY VAN TRAILER (A59910)
2014 HYUNDAI...
