What is this hole on the transmission for? (JD 5085E)
   / What is this hole on the transmission for? (JD 5085E) #21
I'm about to put down a deposit on Tuesday for a 5085e. Would you recommend it?
   / What is this hole on the transmission for? (JD 5085E) #23
if it was a vent you would think it would have some kind of a filter/ check valve to keep dirt and debris out.
   / What is this hole on the transmission for? (JD 5085E) #25
what puzzles me most is that it is a threaded hole..
   / What is this hole on the transmission for? (JD 5085E) #26
Many times there is a cotter key in the hole. It is put in loose enough to jiggle around. This keeps the hole free of debris.
   / What is this hole on the transmission for? (JD 5085E) #27
It's a bad seal or the gasket on front of trans, if it has one. Better get it fixed before you have to buy a new clutch.
   / What is this hole on the transmission for? (JD 5085E) #28
I've ran the tractor 3 times since I posted the OP, since my dealer won't be open until tomorrow.
The first time, I ran it about 30 minutes. No leaking.
The second time was about 1 hour, there was some dripping afterwards.
Ran today for about 2 hours, no dripping.
I think we should hold tight and not speculate, as the last Magicman reported on Sept 1, no leak.
And the serviceman was going to check it out maybe next week.
   / What is this hole on the transmission for? (JD 5085E) #29
No problem with it. Buy the tractor, use it and have fun.
   / What is this hole on the transmission for? (JD 5085E) #30
so dirt wont hurt baby tractors
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2024 Suihe Storage Shelter (A56859)
2024 Suihe Storage...
UNUSED IRGC40 Battery Powered Mini Golf Cart (A55272)
UNUSED IRGC40...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
2007 Chevrolet Silverado 1500 Pickup Truck (A56858)
2007 Chevrolet...
