And now for something a bit different.
/ And now for something a bit different. #1
hydriv
I am putting together a stationary lift platform that will allow me to store garden tractors at ground level, a mid-point level and also at an upper level.
To do this, I bought a mast and forks from a forklift truck that had been sold to the metal recycling yard and after welding some feet on the mast, it is now securely fastened in place. I made some fork pockets from 1/4 wall rectangular tubing and then welded up a 4 X 8 platform to those pockets. Essentially, this is a hydraulic elevator and I want to power it as follows.
I have a C-face - 56C Frame Baldor single phase electric motor that is 1 1/2 HP and spins at 1750 RPM that will allow me to bolt a pump adapter to it and then add a Type AA gear pump that is .61 cubic inches using a Lovejoy style of coupler. This should give me around 4 1/2 GPM or so to feed the 4" diameter single-acting hydraulic cylinder that raises the forks. I am assuming it to be a 4" cylinder since the circumference is about 12 inches.
I have a brand new 5 gallon reservoir that has a 1 1/2" FIP outlet that will be bushed down to supply the oil to the inlet opening of the pump. It also has a 3/4" FIP inlet that I intend to add a 3/4 X 1/2 X 1/2 tee fitting to. My intent is to have the output of the pump feed the INLET of the control valve I have. The OUTLET of that control valve will hook to the Tee fitting and that will allow the oil to constantly circulate through this open-center system. The reservoir will be mounted above the motor/pump combo so as to provide a flooded-inlet situation.
As it happens, I have had a Gresen control valve kicking around on my shelf for the past 30 years and now I think that it will work just fine for this application BUT... I cannot seem to find any specs for it. Here is what I can tell you. It is a Type 2701 single spool valve that is spring loaded for center return and no float feature. The work ports are 1/2" FIP. It appears to have a Power Beyond port in it, which I will plug up, since it is not needed. I intend to connect ONE work port to the bottom inlet of the single-acting lift cylinder of the forklift mast and the other work port will be plumbed to the Tee fitting on the reservoir. The valve appears to have a cartridge style relief but I have no clue as to what spring is in that cartridge..... and that is of some concern to me because I want to protect the pump.
This is a two-stage mast and I cannot visualize me ever raising the mast to full height and topping out the cylinder travel. I am guessing but I think that this fork truck was rated to lift at least 6 tons and I cannot visualize me ever asking it to lift more than 3/4 ton. I am including the weight of the forks, movable mast section, platform and garden tractor in that estimated figure. However, the cylinder rod pushes on a pair of rollers that have two chains around them. One end of the chains is fastened to the fork carriage and the other end is anchored to the mast and this set up essentially doubles the lifting height of the cylinder but also doubles the load it must lift.
Lift speed is not important compared to having a nice smooth, controllable lift to the 4 foot level and then the 9 foot level. The same applies to the descent and if need be.... I have an adjustable flow control that I could add to either or both of the work ports.
Here are my questions:
1. Will I be OK with using the 1 1/2 HP motor?
2. Am I on the right track with the plumbing?
3. Do you see anything that I have overlooked?
/ And now for something a bit different. #2
Every hydraulic valve has leakage so if you lift somethind up it will slowly come down. In other words you can't rely on hydraulics to keep it where you put it. You will need some kind of mechanical means to secure the platform when lifted in example ratchet. I would install electrical switch similar to circular saws.
Object moved
Good luck with the lift.
The valve being used is brand new even though I have had it for 30 plus years..... it has never been put in service. While you do make a valid point, the fact is that the platform will only stay in an elevated position for a matter of minutes....... just long enough to either move a GT onto it or off of it. When not in use, it will remain in the fully-down position. Thanks for your input.
/ And now for something a bit different. #4
I hear you loud and clear but I would still put a mechanical safety latch on the mast to hold it at the levels you are working at. It only has to fall once. Someone only has to bump the lever once.
/ And now for something a bit different. #5
Your pump turning 1750, and with a displacement of .61, the pump GPM will be 4.5.
At 1500 psi and 4.5 GPM, you need 5 HP .
If the pump psi is rated at 3000, you will need 9 HP.
Your 1 1/2 HP motor pumping 4.5 at 750 psi requires about 2 HP
If you can split the flow and use 2 GPM, and regulate the pressure to 1500 2 GPM = 2 HP
A 4 in cyl bore, and 2 in rod, 1500 psi force = 18,850 lbs
/ And now for something a bit different. #6
If anything I think you may want the lift to move slower. I would not be concerned about the strength of the fork lift mast while picking up a garden tractor, this should be an easy load for any of them to handle. Even a small pump package with enough reservoir will work in this case similar to the truck lift gates and dump trailers. These are available in applications for ac and dc power too. Point being that your set up is plenty big enough for your purposes.
Many years ago I bought a three section fork lift mast and set it up to work on a Case 1370 tractor with duals and cat 3 hitch, worked pretty good but if doing it today I would build a frame hitch for it. That thing was really handy to have while building a large shop and home, forks could raise over 24' above the ground. Being fastened to a 150 hp field tractor made it manageable for hanging red iron.
/ And now for something a bit different. #7
JJ's calculations are accurate imo but I doubt you will need to be anywhere near the 1500 psi to make this lift work for your use. 300 psi would be a more likely pressure without doing the math.
A safety lock of some sort is a good idea as others mention.
/ And now for something a bit different. #8
It's the load that will determine the pressure.
So what is the max load you expect to lift.
/ And now for something a bit different. #9
Deleted
/ And now for something a bit different. #10
Good advise so far. I'll add some input:
I am betting the cylinder is 3.5" though, if the outside circumference is ~12". That will make it faster and less powerful. A 3.5" cylinder is usually found on forklifts rated to lift 4000-4500#. So the mast is still pleanty strong. As long as you have a good solid anchor to the floor.
IF you want/need to lift something in the ~1500# range, I'd shoot for 2000# capacity. That will cover the weight of the forks, and fork carrier plate.
So, to lift 2000#, with a 2:1 ratio the chains give, you need the cylinder to make 4000# force. To get that, you need ~416 psi to do the job. So lets call it 500psi. With only 1.5HP, you can deliver 4.3 gpm max before you overload the motor. (electric motors wont stall, but will continue to draw amperage till they fry). Your 0.61 cu in pump is 4.6GPM @ 1750 rpm. I think if you already have the pump, thats close enough to try.
Might be a tad on the fast side though. Extend speed of the cylinder would be 1.8" per second, with the 2:1, the lift would lift 3.6" per second. Or 10 seconds to lift 3'.
As to the plumbing, on the pressure side, make sure you only use steel hydraulic fittings. No black iron fittings or bushings like you would find at the hardware store. Make sure you go to a hydraulic shop, or order online from a hydraulic supplier. And I also didnt see mention of a filter set-up?
Without dismantling the forklift mast and then weighing the 2nd stage mast, the pair of forks and the fork carriage, I am just guessing that these items will not weigh more than 600 LBS. The platform will likely come in at 300 LBS.... so let's assume 1000 LBS total to be on the safe side. The GT's will top out at 800 LBS. Realistically, I was hoping for a 2000 LB lift capacity here.
But since this is a two-stage mast, isn't the cylinder actually seeing 4000 LBS due to the doubling effect?
The choice of pump was dictated by using something I already owned but perhaps I will end up buying something in the .30 CI size.
The cylinder shows no signs of leaking from the top seal but...... I cannot vouch for the piston seals at this point. The overall length of the cylinder is about 80 inches so the total stroke will likely be a few inches less. I am thinking that it would take around 4 gallons of oil to fully extend the cylinder. So at 2 GPM, it would take a full two minutes to reach full height. This seems rather slow but on the plus side, it is a very controllable lift rate that would allow for highly precise stops at any point. The last thing I want is something that is twitchy, jerky or erratic.
jenkinsph.
I have not witnessed this mast in operation so I do not know for sure if the forks and fork carriage lifts first to its maximum height and then causes the 2nd stage to start lifting. I am guessing that this is how it will function. I am all for safety but I think that trying to install some sort of mechanical device to hold the extended mast in two locations would be difficult initially and cumbersome to employ. I am open to all suggestions.
/ And now for something a bit different. #12
YES
Likely a 72" stroke cylinder. With a 3.5" diameter cylinder, it will take 3 gallons to fill. If it were a 4" cylinder, it would indeed take 4. But if you say the outside circumference is ~12", there is no way its a 4" cylinder. A 4" bore cylinder would likely have 3/8" walls. Thats a 4-3/4" overall diameter, which would be lots closer to 15" circumference.
Any way you can get a more accurate measurement?
And yes, it is typical that the entire first stage will lift first, then the second stage will kick in.
Got any pictures of the mast??
I am betting that you are correct in assuming a piston diameter of 3.5 inches. The OUTLET side of the pump will connect to the control valve by way of high pressure hydraulic hose and no plumbing fittings. However, the Tee fitting at the tank will be a plumbing fitting since the pressure there will be less than 300 PSI. Even so, I will use high pressure hydraulic hose on both return lines......because I have plenty of it and it will never give me any problems.
This is a solution to a problem I have with respect to storage of my GT's. By going this route, I do not have to maintain a proper fork truck or FEL of some kind. I feel that this setup will be at my beck and call 24/7, not consume any gasoline or diesel and not take up any valuable space. It will only be used on an occasional basis in order to either retrieve at GT so it can be restored or to put that GT away once the restoration has been completed. In other words, it is going to sit around and do nothing for most of the year but when I need it....... then it is there for me.
YES
I will take some photos today and then post them. I will also take some measurements of the mast height etc. I do not own a caliper that can measure the true OD of the cylinder. I won't be back on here until after suppertime tonight.
/ And now for something a bit different. #15
Can you get on it with a c-clamp, then measure the opening of the clamp with a ruler?
Here is a photo of the mast from the front.
I welded angle iron to either side of it and then used expanding anchors to bolt it into the concrete. Those nuts are 1 1/2" in size and I used my four foot torque wrench to tighten them.
Currently, it is standing just fine on its own BUT.....to give it some additional support, I welded some 1/2" thick x 6 inch wide flat bar to a length of wide-flange I-beam and then used the same type of anchor bolts to secure that upright to the solid concrete block that the mast sits on. These blocks a 3 ft by 3 ft by 6 ft long and make up my "loading dock" retaining wall for the trailers.
I am going to run two lengths of 1/2" threaded rod between the I-beam flange and the heavy cross support on the rear of the mast. The threaded rod will have nuts on either side of where it is bolted to those two items so that it is "passive" and they do not have any tension on them unless the forklift is in use.
The height of the mast between the concrete block and the top of the channel is 91 inches. The width of the mast assembly is 22 1/4 inches.
The width of the fork carriage is 36 inches and it uses 42 inch forks that are 4 inches wide by 1 5/8 inches thick in the vertical section.
The highest the forklift must rise is 9 feet to reach the top of the trailer roof.
I can use a C-clamp on the cylinder later today to get a more accurate OD and then post it here.
/ And now for something a bit different. #17
With the rear supports, I think you will be fine with what you want to lift.
IF you already have a 0.61 cu in pump and 1.5hp motor, I'd say try it. But put a amp clamp on the motor leads and watch the amp draw and make sure you dont exceed the nameplate amps x S.F.
If you dont already have a pump, I'd downsize a notch to be safe.
And BTW, that is a single stage mast.
/ And now for something a bit different. #18
You could do a simple load test.
One pallet, two 55 gal drum full of water should equal about 1000 lbs, and note the pressure when load is lifted.
If showing about 500 psi, then the 2000 lbs should take about 1000 psi.
Your pump pumping 4.5 GPM and 500 psi requires about 2 HP. Your pump is 1 1/2 HP
I would do some lift test before you get fully engaged in the project.
If you have a tractor, use it for the test or a friends tractor.
Without question, I truly appreciate all of the advice and feedback thus far. Perhaps it is just my own vanity talking here but I think that some members find this thread rather interesting because it pits the theoretical aspect against the actual end result. I have every confidence in J J's input but in order to put it to the test, this is what I will do. I intended to dismantle the mast anyway to clean it up, inspect it thoroughly for any problems and then repaint it before assembling it and putting it back in place.
As it happens, I own a platform scale that is capable of weighing up to 2000 LBS very accurately because it uses no springs, just counterweights. I am going to weigh the pair of forks, the fork carriage and the inner mast stage.... all of which the cylinder is required to lift. No matter what, I need to make the platform to go onto the forks and I will weigh it as well once it is completed. Because I already own the electric motor and gear pump, I will proceed with finishing the power pack using those items and I will add a pressure gauge capable of reading up to 2000 LBS. All of this will be photographed and noted for my future posts. Once the work is completed and the lift is operational, I will do a test run with absolutely nothing on the platform to see how much pressure is being generated. Adding fixed amounts of weight to the platform is not a problem because I can scale those items first and then use my Case skid steer to place them on the platform. The changes in pressure on each test will be recorded.
It is far cheaper for me to purchase a smaller pump for around $100.00 than it is to purchase a 5 HP motor. I just bought a 5 HP motor for the air compressor I am building and it cost me $328.00. I will likely be a couple of weeks before I can get to this but when I am done, I will report on what happened.
/ And now for something a bit different. #20
Sounds like a good plan. Keep us posted.
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
UNUSED WOLVERINE TREE DIGGER (A64281)
UNUSED WOLVERINE...
2007 International 8600 Parts Truck (A63689)
2007 International...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
