rswyan, someplace here on TBN I have pictures of the grapple I built for my
B2910.
Ron,
Thanks ... I'll poke around and see if I can find anything and have a look.
Great tool for hauling logs and yard cleanup.
That's my primary intended use ... have a lot of brush and fallen trees and branches that needs picked up and relocated ... as well as a bunch of logs that I need to cut up for firewood.
But not much for grubbing out shrubs. Need a bigger tractor for that.
Yeah ... the
B2910 is pretty light as far doing that type of stuff I would think.
Though I do have probably 600'+ of fence line that is overgrown that I'm hoping to clear ...
I guess the biggest thing will be how far out the nearby tree roots extend into the area I need to clear. This area was cleared to about 15' from the fence on my side by the neighbor when he installed the fence originally (15+ years ago ?) ... got the other neighbor to come in with his mini-ex and little dozer pop out all the stumps ... it has since grown up considerably.
He was keeping it mowed and sprayed (on my side) ... but when he sold the property the new owner did not keep it up and the jungle is taking over ... the shrubs and brush are probably the height of my head (or more) when sitting on the
B2910.
The one I'm building is modeled after the WR Long RGB series ... but with some modifications (larger cylinders for one) ...
This is a picture of the "RGB-48" that TBN member NHBotanut has on his
B7610, which is the model I'm using as an design example/template:
I'm using 1/2" x 3" bar stock for the bottom rake teeth, with 1/4" plate for gussets, welded to 3" x 2" x 1/4 wall rectangular tube as a cross bar ... even so, I'd consider it a pretty light duty grapple. Not planning on trying to go wild with it, as far as ripping stuff out of the ground ... the
B2910 just doesn't have enough *** for that, and the stresses on the loader could be pretty significant I would think.
wngsprd, my OEM battery lasted 12 years. Replaced it with a new Kubota battery. It was expensive. But if it last as long as the original. It is a good deal.
I got about the same out of my original battery ... replaced it with one from Autozone ... we'll see how that goes ...
