North Georgia
Understand Kubota has come out with a new line of hay equipment..(Bought someone out in Europe) Wonder if this is the Vicon line????Anyone know????
Neil,
How will this effect the current relationship Kubota seems to have with Vermeer?
Neil,
When Kubota paints this Orange and gets them on the lot then maybe they'll have some hay equipment worth a serious look. Kverneland 4332 CT Disc Mower Conditioner - YouTube
well since kubota is going to re brand the vicon cutter.they better fix any probs that vicon might have.because their name is new to the hay game.
I also had a snag when got my Vicon CM2400 but it didn't have anything to do with Vicon but the dealer I purchased it from put something together wrong. I sent pictures to them cause I wasn't going to load and haul back and showed them what they done wrong,for future ref. but I was able fix it pretty easy.Well I already found one problem. I bought the 10.5 ft disc mower (orig the vicon EXTRA232) and have a problem with the hydraulic cylinder hitting the nearby frame support arm when in the full transport position. The dealer's "fix" for this was to move around a couple of spacers to the "wrong " positions according to the parts diagram (and pictures of other mowers I can find ) in order to work around the ACTUAL problem which is ???? This is totally unacceptable as now it has two articulating frame pieces touching each other without so much as a washer in between, not to mention it's NOT how the mower was designed. HOWEVER, it cuts and operates great. Just this little snag but I'm not accepting it back from the shop like they have it now. They need to find the problem and correct it or take it back. Figures I would get a freak problem like this. They must have screwed something up when they uncrated and assembled it.
I've attached a picture of what it's supposed to look like, one spacer above and one below the flange, on mine they put them both on top.:thumbdown:
Jeff
They must put yours together like mine on a Monday or Friday,lol. It should be easy fix,just like you said don't take it until it's right. Some times only way get something right is to do it yourself,it seems...
