John Deere Question
/ John Deere Question #1
Eastwood72
Correctionville, Iowa 51016
1971 John Deere 4020
I have a 1971 John Deere 4020 and would like to know the correct weight that fits the back Rear Cast Wheel R33430 of this tractor ? I have weights A3404R and they dont seem to fit ! thanks Eastwood72
/ John Deere Question #3
If the weights come from an older series of tractor they won't fit properly as you discovered. If the weights are of no value as antiques then a bit of work with a cutting torch and they fit. The first weight installed just needs to be trimmed in the center of the circle. I've done it before but it was 35 years ago and I don't remember exactly where but I remember that it wasn't difficult. You only need to do the first weight and if your careful you can't see what is cut off as it fits against the cast center.
thanks from Alberta , as i will look this over see if that could work or start over and look for different weights.
/ John Deere Question #5
Welcome to TractorByNet!
We moved your thread to the John Deere Owning & Operating forum. :)
/ John Deere Question #6
Eastwood
If you go to jdparts.com and look up model 4020, you will find the different wheel weights under the alphabetical listing and the part no.s there.
There are several selections depending on wheel size. i.e part no. R61727 for 30" wheel. Larger diam. says NLA for no longer available.
/ John Deere Question #7
I think you didn't read casting # for rear wheel correctly as there's no PN R33430 but there's a PN 33450 in the late model 4020 PC.
R33450 DISK 1 ((A) AND 4000 SERIES) (SPECIAL OFFSET) (15.5-38, 16.9-38, OR 18.4-38 TIRE AND RIM) (SUB R70309)
This weight is for 34" & 38" cast wheels but doesn't specify "offset".
R61524 Weight Kit - WEIGHT, WHEEL ADD 358.60 USD
2016 Freightliner Columbia 120 Glider Day Cab Truck, VIN # 3ALXA7CG9GDGZ6492 (A61165)
2016 Freightliner...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2013 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR2DJ296618 (A61165)
2013 International...
New/Unused Wolverine 78in Land Leveler (A61166)
New/Unused...
UNUSED WOLVERINE TF1-66-4000G-66" PALLET FORKS (A62131)
UNUSED WOLVERINE...
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
