New Kioti CK35 HST Approaching 50 Hours
   / New Kioti CK35 HST Approaching 50 Hours #1
GuyInHuntsville
Texas
Kioti CK35 HST
Hi everyone, I'm new here but I've been reading for a few months now and I just became a 1st time tractor owner. It was delivered Monday of last week. The 1st time I ever drove a tractor was test driving this one. I'm quickly racking up hours on it...Seems like every 30-40 minutes operating it equals a full tractor hour. Maybe I'm pushing it too hard. I'm already at 31 hours and prepping for the 50 hour maintenance and have read here about how hard it is to remove the hydraulic filter...Some people here in past threads have said one strap wrench or another while others have said those broke and suggested something else. Can anyone tell me a specific filter wrench that's proven to work so I could purchase it, maybe at an auto parts store or Amazon? A photo of it or model#? Thanks for reading.
   / New Kioti CK35 HST Approaching 50 Hours #2
Chain Wrench
   / New Kioti CK35 HST Approaching 50 Hours #3
I have a Bobcat CT 235 which is roughly the same tractor.
I had no problems with removing the oil or hydro filter the first time through. So, don't be overly concerned or worried.
I used a simple strap oil filter wrench purchased at Auto Zone. It worked just fine. Just go slow and steady and get as good a grip as possible and all will be fine.
Good luck.
MoKelly
Thanks Guys and thanks for the reassurance MoKelly. I was worried from reading all those posts. I just called the dealer and the parts guy told me they don't even recommend changing any of the hydraulic fluid or filters because the HST "has filtration out the wahzoo" and it's 1st change out should be at 200 hours. Should I trust his recommendation? He said to just change the engine oil/filter and front axle oil at 50 hours.
   / New Kioti CK35 HST Approaching 50 Hours #5
There has been lots and lots and lots of debate/discussion here on whether or not to change hydro oil at 50 hours. You can look it up if you want. I'm not sure it will sway you either way. You just have to make up your own mind.
I did the change at 50 hours.
MoKelly
   / New Kioti CK35 HST Approaching 50 Hours #6
I changed mine at 50 hours.
Sure, you can wait as long as you choose - but - my feeling is, you can't change fluid and filters too often but you can certainly change them too infrequently.
   / New Kioti CK35 HST Approaching 50 Hours #7
I changed engine oil and filter, front axle fluid and changed both Hydraulic and HST filters and top off fluids. This procedure was from my Dealer.
   / New Kioti CK35 HST Approaching 50 Hours #8
Welcome to TC. Your first 50 hour maintenance should of been included in your purchase. I know for a fact my CK30 hst 50 hour maintenance will be done by the dealer coming to my house. The labour is free but I have to pay for the fluids which is fair, at the same time gives me a chance to sit and watch what needs to be changed and the location of all the fluids fills, filters etc for future reference when time comes for me to do it myself. So check it out with your dealer first before trying to do it yourself.
   / New Kioti CK35 HST Approaching 50 Hours #9
I am like you....tractor newbie. I purchased a used CK20 with 97 hours 2 months ago. The tractor had warranty work at 27 hours then the original owner owned it. The tractor had easy hours on it (mowing, plowing, firewood hauling with a few stumps removed with the backhoe.) All the fluids were changed at that service except the front axle. Being crazy about mechanical maintenance I decided to research all the fluids and replace everything. Glad I did. The hydro fluid was pretty contaminated even though it was changed out at 27 hours. All sorts of stuff came out the drains (small pieces of metal and even what looked like gray RTV). I even saw some metal with orange paint in the bottom of my drain pan. The magnet on the main drain was only half covered with metal (don't think this was that bad). The stuff that came out the drain and was stuck to the bottom of my drain basin after dumping it was a little shocking. I'd change it.
Thanks K man. I asked the dealer about this when I bought it and he said it was my chore to do the 50 hour maintenance and that they will not ever perform house calls...All work they perform must be done in their shop. It sounds like you have a great dealer and it supports a long held belief of mine that Canadians are nicer than we are down here at least in Texas (hope I don't get slammed for saying that).
Thanks Stickyhb for telling me this. I'll definitely do the full maintenance. I've read elsewhere here about the same trash and shavings in the oil so I better not skimp on the maintenance. As for being a newbie to tractors I think I'm as rookie as one can be....Still trying to figure out how to best use my ratchet rake and how not to tear up my tractor...Already broke a tail light pulling out a tree that came down and hit it.
   / New Kioti CK35 HST Approaching 50 Hours #12
I guess us Canadians should get some kind of a freebee cause we pay a lot more for everything. All Kioti owners here in Canada get the first 50 hour service free. This way they will see if there is any damage done during that first break in period. I live in a remote area so that may be the reason why they will do the house call at no charge other than the fluids and filters..
   / New Kioti CK35 HST Approaching 50 Hours #13
This is the ONLY thing that got my hydraulic filter off and that was after numerous tries of various strap wrenches over two weeks or so, along with borrowing a large, stronger friend who barely got it off on his second or third try. Crescent CW15 15-Inch Chain Wrench - Adjustable Wrenches - Amazon.com
If the rear wheel had been removed, it would have been easier. However, no way that was going to happen. At my 50 hour mark I changed all lubricants and filters as they are relatively inexpensive insurance. My magnetic hydraulic oil drain plugs had large piles of gunk stuck to them.
Thanks sdef! That's exactly the info I needed...I'm ordering it right now through Amazon. Hopefully like MoKelly said, maybe I won't have too much of a problem but at least I'll show up with a proven wrench, along with a cheater pipe.:)
   / New Kioti CK35 HST Approaching 50 Hours #15
You are welcome. This was a very trying process for me. The filter is strongest at the bottom, by the closed end, so get your grip there. Kioti is known for having a gorilla tighten this filter, along with the hand throttle assembly.
If your hand throttle is difficult to move take a look at this easy fix: http://www.tractorbynet.com/forums/...286824-kioti-dk-throttle-lubrication-pix.html
   / New Kioti CK35 HST Approaching 50 Hours #16
Smart move in my opinion:thumbsup:
Thanks k0ua!
Before I logged into Amazon I went to a guy where I work who has a lot of tools and I lucked out. He's loaning me his chain wrench that looks just like the one sdef recommended. Williams WC-4. And a cheater pipe for extra leverage. Let's see if I can post a photo for those seeking out the same info as me.
   / New Kioti CK35 HST Approaching 50 Hours #18
I think you'll only need that chain wrench for the first time. My first removal was hard but after that, a rubber strap wrench works fine. Enjoy the new toy!
   / New Kioti CK35 HST Approaching 50 Hours #19
True, you are not going to put that filter back on like the big ole gorrilla did at the factory. I wonder what they pay him.:)
   / New Kioti CK35 HST Approaching 50 Hours #20
I haven't reached 50 hours yet so no maintenance done. But I do have a question about the schedule I have for a nice TBN'er (online manuel).
For instance on line 1 it says engine oil get's change first at 50 hours. Then it has a star in the 100 hour block. I assume it means it's every 100 following. Same with the engine oil filter, first time is at 50 hours and then at 200 hours and I assume every 200 hours after that. Typically with a car or bike the oil filter get's changed with the oil, right?
2009 Kubota RTV1140 (A57148)
2009 Kubota...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2014 Ford Transit Connect XLT Passenger Van (A59230)
2014 Ford Transit...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
