My new Kubota with Air ride seat
   / My new Kubota with Air ride seat #52
Wel,l I had to send back the Grammer MSG95 the base of the seat was to wide. I re-ordered a MSG75 just like DDT's bought the cover from the M- series from my local dealer just waiting for the new seat. Question for DDT: did you add more bolts to the OEM seat pan or just use the 4-on top and the 2-in front? Also how many bolts did you use on the MSG75 seat base? Thanks
oh yea, what's the going rate on a used-almost new L5740 seat?
Pegneck, I use the 4 on top for both the pans and the two in front for the OEM pan, the seat mounts to the rear of the seat pans. seat is strong and soild.
   / My new Kubota with Air ride seat #54
DDT, thanks for the reply. My seat just showed up and I'll install tomorrow. I noticed the electrical connection has 5-wires square plug. Do I need all 5-wires or just 2 to get 12volts to the seat? Which wires did you use?
Pegneck, I thought that info with seat instructions....might be able to find in on the net to?
   / My new Kubota with Air ride seat #56
no wiring instruction,in the box mine has a white male plug with 6 connectors
   / My new Kubota with Air ride seat #57
found instruction online....thanks
   / My new Kubota with Air ride seat #58
DDT, Seat installed just like you did what a difference! Question on wiring, I used add-a fuse and have it connected to the dome light which is always on(key on off position) does this matter? Or should it be controlled with the key on...ie radio ? Thanks
You will have to pump it up every so often to keep the needle in the center of window, thats the only time it uses power. Your choice. I dont remember how I wired mine.....been to long now, might have to look...
   / My new Kubota with Air ride seat #60
Air ride seat on about anything
With hardware, steel and determination you can put an air-ride seat in about anything. I helped this guy who was crushed by a horse and had severe back pain install an air-ride seat in an old Belarus tractor. Gary McDonald uses an air-ride seat to cushion his back.jpg
(4) ELECTRIC MOTORS (A54757)
(4) ELECTRIC...
2013 FORD TRANSIT CONNECT VAN (A52708)
2013 FORD TRANSIT...
CAT 930M (A58216)
CAT 930M (A58216)
ROBIN AIR 34788NI A/C RECOVERY MACHINE (A58214)
ROBIN AIR 34788NI...
1999 Eagle Road Tractor (A55272)
1999 Eagle Road...
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
