What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor?
   / What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor? #1
jockofrommorocko
Cowra NSW Australia
John Deere 4230
I own a John Deere 4230 model tractor that doesn't currently have a 3 point hitch (linkage) fitted. I am interested to know of the required parts and where I can buy these, or better yet to purchase a complete kit of all required pieces and fit these.
I am located in Australia - and assume the parts will come from the USA and have these posted to me.
Please help! Thanks
   / What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor? #2
Welcome to TBN...
Have you checked with you Dealer?
I don't have them for my 110 Deere and found they are available through Deere... decided the cost didn't make sense for the way I use the tractor.
   / What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor? #3
Does your tractor have a rockshaft housing as shown in parts photo? Does your tractor have the drawbar support as shown in parts photo?
No it doesn't have a rock shaft housing or lever inside the cab. Can I purchase a rock shaft and fit this to lift the side shafts?
   / What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor? #5
I think you'll have to get a donor tractor or contact a salvage yard for the parts. Retrofit will require some extensive amount of labor possibly including R&R of rear axles & ring gear if your tractor doesn't have this mechanism.
What if I were to mount the two side draft links and mount a hydraulic ram in the centre to lift? The hydraulic ram would then become the centre link and be plugged into the existing hydraulic sockets and be used by the levers inside the cab?
   / What required parts are needed for a 3 point hitch to suit a John Deere 4230 tractor? #7
I think mounting a hyd cyl similar to center link will give you very limited height when trying to raise 3 pt implement.
I thought of putting a ram with a stroke of at least 400mm on it to lift at least this height.
What height does a standard 3point hitch lift off the ground?
I ended up mounting two 8" hydraulic cylinders and made to side draft links. Works perfectly and plenty of lift 'higher and lower than a standard 3 point link'
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
PALLET OF MISC PARTS (A52708)
PALLET OF MISC...
2019 Komatsu WA380-8 Wheel Loader, S/N A75147, PIN# KMTWA130TKNA75147, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2016 Ford F-350 (A56858)
2016 Ford F-350...
