That's a 4 cyl as stated, pre-65 like my '63 2000D. My '65 3000D is 3 cyl. Both are smooth operating and really have no preference. However when I bought my Branson I did want the 4 cylinders. Funny on engine technology. I had a 1979 or thereabouts 3 cyl Ford 4600D at 200 cu in and 1800 PTO speed putting out about 40-45 hp. My Branson has a Cummins 200 cu in and is brake rated at 65 built in '07. Ha, just dawned on me the extra rpms are the source of the additional hp so I guess there isn't all that much new rocket science after all for naturally aspired, direct injected engines. Just ran the ratio of 1800 to 2600 and it's right on the HP number differences.
I've had zero problems with my 4 cyl and at 3600 hours it's still a pony. Had to replace the water pump recently and a starter year or so ago. Have some leaks but no big deal. Best I can tell the tractor is all original and no major surgery. Good tractor. I had to overhaul the 3 cyl but that wasn't the tractor's fault. PO abused the heck out of that machine.
Edit: On bone yard picking, you need to know if the engine is out of the same tractor since the cubic inches and HP of the 4 cyl 2000 and 4 cyl 4000 are different. As I recall the cubes of the 2000 are 136 and puts out about 30 hp and the 4000 cubes are 178 putting out around 40 hp at 1800 PTO rated (540) rpm. On telling the difference in just looking at the engine Soundguy can probably put you onto that.
Mark
