445 Tractor Serial Number
/ 445 Tractor Serial Number #1
narampa
canada
445 johndeere
According to my tech manual there is supposed to be a Decal on the R/F of the engine block. My tag is missing.
I found on the air cleaner the following.
FD620D
Family ID SKA617U5G2RA
Manufacture Date 10/96
What I am trying to determine is this the serial # and what are the timing gears made of.
I bought this tractor with 18 hrs on the clock at a garage sale. The original owner has long since moved away.
It is now over 950 hours and I don't want to start eating pistons because of nylon gears.
40 years as a mechanic but no experience with John Deere.
Your help would be appreciated.:)
/ 445 Tractor Serial Number #2
Since you have a date of 10/96 I'm guessing its the lawn tractor and not the farm tractor with the 2 cyl. diesel. 96 serial numbers started at 040001 up to the 97 serial numbers starting at 050001. Yours should have a number starting 040XXX. Decals have a tendency to come off when tractors are hosed off a few times. The 040XXX number should be stamped somewhere. Maybe a Deere dealer could answer your question. I would think nylon gears would have worn out long before 950 hours but not familiar with the engine.
/ 445 Tractor Serial Number #3
I believe it is stamped in the main frame towards the back behind the rear wheels. I don't remember which side. The engine was assembled 10/96 so the tractor could even be an 98. Most likely a 96 to 97.
Yes it is. I meant I need the engine serial #. My mistake. I was wondering if the# on the cleaner is the#?
1994 SHOP MADE ENCLOSED TOOL TRAILER (A63569)
1994 SHOP MADE...
CUSTOM HEAVY HAUL 78" X 16' DBL AXLE TRAILER (A63745)
CUSTOM HEAVY HAUL...
2019 INTERNATIONAL 4300 26FT BOX TRUCK (A59910)
2019 INTERNATIONAL...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2000 Mack CH613 Dump Truck (A59213)
2000 Mack CH613...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
