Buying Advice Mahindra 6110 Is it ok ?
   / Mahindra 6110 Is it ok ? #1
JMHTX
Montgomery, TX
2014 John Deere 5055 E Cab
For people that own - use - sell this Tractor Mahindra 6110 ... Is this a good economical reliable Tractor or a
3rd World bucket of bolts rattlin bablin Hunk of Junk ?
I've got about 15 acres to mow and clean up, and maintain. I mowed some last week with a 25 YO Ford 18HP Blue tractor
Whata joke, if it got close to thick grass it bogged It just sort of whirled the grass unstead of clean cut. And I got stung by
some kind of Red Hornet looking flying bug.
So I'm thinking a cab is a good thing. 59 HP.. Should be enough to adequately run a mower.. Price seems to be a good deal.
Whats the report on this tractor or should I consider something else ?
Thanks !
   / Mahindra 6110 Is it ok ? #2
Thanks !
Using the review feature on the home page of Tractor by Net, I found this: Mahindra 6110 Shuttle Cab Review by Jeffrey Canada - TractorByNet.com
Overall Rating:
rating
4.00
Build Quality:
5
Features:
rating
5
Performance:
rating
5
Value:
rating
5
Reliability:
rating
4
Add your review
Print Review
Mahindra 6110 Shuttle Cab Posted by Jeffrey Canada on 06/23/2014
Very strong tractor. Pulls my 4-bottom plow and heavy discs with ease. Finding the right gear settings between low/medium/high and 1-4 can be a job, but it comes with experience. The only problem I've had is the air conditioner squeals sometimes under the hood when I turn it on when it's hot outside. Otherwise, I'm very satisfied.
ITEM INFORMATION
Model year: 2014 Date Purchased: 03/05/2014 Number of Hours: 73
REVIEWER'S ADDITIONAL INFORMATION
Pros: Strong and quiet. Cons: Air conditioner squeals from under the hood sometimes. Type of User: Homeowner 100+ Acres Location: United States North Carolina
   / Mahindra 6110 Is it ok ? #3
Don't forget to sharpen the blades on your mower so it doesn't just tie knots in the grass.:D
   / Mahindra 6110 Is it ok ? #4
If you want to save a bundle, take a look at the Mitsubishi built, 3616, 3616 4WD Shuttle Cab | Mahindra. In my opinion, from what you've said, you don't need a 6110 for a mere 15 acres. The 3616 has double the horsepower of your old blue tractor; it should be plenty enough for your land. Take a look at just one satisfied owner has to say: http://www.tractorbynet.com/forums/...ing/246759-new-mahindra-3616-shuttle-cab.html
The Japanese build very good tractors, especially the ones badged, Mahindra, and the older Cub Cadets.
Self Leveling Rotary Laser (Survey Equipment & Grade Control) (New/Unused) (A59225)
Self Leveling...
2013 CIMC REEFER TRAILER (A58018)
2013 CIMC REEFER...
2015 Ford F-350 Cab and Chassis Truck (A56858)
2015 Ford F-350...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
LOT: Assorted Hand Tools (A59076)
LOT: Assorted Hand...
