tractor with no thermostat?!
   / tractor with no thermostat?! #101
uh.. sorry, figutred i was talking to a audience that would be capable to follow progression i could omit a few quite obvious steps..
like stop tractor. block tires, loosen lugnuts, jack wheel up, take wheel and tire off.
break down tire bead
yada yada yada
of course you take the %$#@ thorn out.
sheesh.... ;)
Sorry there Mr. Perfect but in your progression of steps you forgot to mention mark the valve location on the tire so if he has a tube he can match up the problem area on the tire to find what caused the leak. It is not uncommon for people to tube a tire that has a thorn in it and leave the thorn in the tire and still have problems.
   / tractor with no thermostat?! #102
sure.. if it's a moron working on the tire!
   / tractor with no thermostat?! #103
No need to get jacked all out of shape. I was just give the OP a heads up so the tire is fixed right.
   / tractor with no thermostat?! #104
not getting jacked up.
there is just a standard progression of things you do when you 'do something'.
If a guy tells me he has a flat tire and I tell him to change the tire. it is ASSUMED he will JACK UP the car FIRST... even thought I didn't specifically say it. IE. it's assumed to be part of the procedure.
just like retubing a tire casing.. you do all the steps needed in order to do so. inspecting the casing is but one of those steps!
   / tractor with no thermostat?! #105
The poor guy is still out searching for a timing light and it is not going to fix his problem.
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2008 CATERPILLAR 304C CR EXCAVATOR (A51242)
2008 CATERPILLAR...
2014 Ford E-350 Cargo Van (A50323)
2014 Ford E-350...
1998 Featherlite Gooseneck Trailer (A50514)
1998 Featherlite...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
