FEL question on G3038
/ FEL question on G3038 #1
kjonfc
Member
Washington, MO
IH 300, Ford 8N, LS G3038
I recently bought my G3038 and started putting the FEL to use right away. I thought the curl was a little weak, but not always so I figured it was just user error and I'd figure it out later. I thought that maybe it needed to be bled so I started to cycle through the curl/dump function and realized that when I would dump, it would get most of the way down, then it was just like the hydraulics would release, kind of like float, the bucket would just hang. If I tried to continue the dump past vertical while it was just hanging there like that, it would not move and if I would try to curl it would take a couple of seconds to start the curl function. Now if I would curl it part way back up then dump, it would behave as expected and dump with power all the way. It's not a random event and I can reproduce this the same way every time. So I'm wondering if this is a "feature" or a problem. I can't imagine it would be an intended function. I hope its an easy fix as my dealer is over an hour away. There is one closer, but when I was shopping around, they didn't sell trailers and offered me a deal that was thousands more than I paid and they were kind of trash talking the other dealerships. Any advice/help is very much appreciated.
Thanks in advance,
Kyle
/ FEL question on G3038 #2
My loader will behave the same way with the exception that once I cycle it fully several times, it will fully dump as I would expect it to. It's almost as if there is an air pocket in there somewhere that needs to get worked out before it will function normally. Aggravating, but so far not a big enough problem for me to do anything about it.
/ FEL question on G3038 #3
Mine is doing the same thing. I talked to the dealer this morning and they told me to take it in and they would check it out Monday.
Eugene
/ FEL question on G3038 #4
Far as I know, it's common. If I've read of a fix, I've forgotten it. If there is a fix, I would certainly be interested.
/ FEL question on G3038 #5
My 4041 does it too, I have to cycle it again and then it's ok!
Guys, I certainly appreciate the feedback and I'm glad it's not just me. I would have called today but I'm a Army reservist and this is a drill weekend for me so I couldn't call today. I hope they can just tell me how to fix it so I don't have to drive an hour, drop it off, drive an hour back then do it over again when it's resolved.
/ FEL question on G3038 #7
Are you trying to do a power dump or a regen/fast dump?
When the bucket is dropping faster than fluid can fill the cyl, you will have some flop, slop, hesitation, or delay.
Regen fills the cyl faster and is supposed to eliminate the problem.
/ FEL question on G3038 #8
JJ --- not sure what the answer to your question is??? I think we're just trying to fully dump at the most rapid rate the valve will allow. Something tells me that this valve doesn't have "regen"???
J.J.,
If you hold the lever in the dump position, it will dump so far, then just flop. If you leave the the lever in that position, it never catches up and pushes the cyl/bucket the rest of the way back. If you then, move it to the curl position, it takes it s few seconds to grab hold then it curls up and if you go to dump again, it seems to work properly being controlled and under power through the whole dump cycle.
/ FEL question on G3038 #10
I am not sure what you guys are doing but my P7010 will kinda flop at one point just before the bucket lip starts to be pushed beyond vertical if I dump the bucket especially if the engine is at low idle. It seems it takes a couple of seconds for the pump to catch up and fill the cylinder before it continues to travel to full dump mode. It will dump fully though without cycling it. I think is it just that the bucket falls faster than the pump can supply oil behind the cylinder. It is not that noticeable when the engine is revved up or if you dump slowly.
Gary, at least in my cans (and I'm assuming in the others experiencing this), It will get to the point you are describing then just kind of flop, but it's like the cylinder doesn't fill and it never catches up. It'll just hang there in "flop mode" until you curl it all the way back up then dump again. Then you don't really experience it at all. With mine at least, it doesn't seem to matter what RPM you are running at the time.
/ FEL question on G3038 #12
See this, copied from Greentractertalk as for some reason linkind url didn't work . . . it may be that the regen function is the issue as JJ suggests.
"Regen is a "feature" of most modern FEL (Front End Loader) valves, it's on the Dump (joystick far right) circuit, and is also referred to as "Fast Dump". The reason it is nice to have is that without it, the weight of a filled bucket can actually "pull" the bucket down faster then the fluid can enter the other side of the cylinder, this will create a air pocket and give the bucket a "floppy" feeling until the joystick is held in the dump mode a few seconds to refill the cylinder pushing the air past the seals. So we add "regen" or "regenerative" function to the valve.
Regen solves this problem by actually filling both sides of the cylinder at the same time with hydraulic fluid. But how will that work you might ask? Well, because there is more volume on the side of the cylinder that extends it since the rod is taking up space in the other side, it "overpowers" the rod side and lets the cylinder extend-thereby dumping the bucket. So since now both sides of the cylinder are "pressurized", the air pocket can not develop, eliminating the "floppy" bucket syndrome. One other added bonus is that the bucket actually dumps faster due to the higher flow rate required to do all this, that's why it's referred to as "fast dump" sometimes.
So, now you may be asking “This is cool and all that, but why do I need to know about it?” The answer to that is simple, if you ever try to run a snow plow with two SA (single acting) cylinders, or a cylinder that drives a chute rotator on a snowblower you will soon find out that they won’t work if you push the joystick to far right in the regen mode. The plow won’t work because since both lines are pressurized-both cylinders will be trying to extend at the same time binding everything up. The rotator won’t work because there is no weight pushing the cylinder closed like there is on the loader.
On most, if not all John Deere tractors there is a “lockout” the limits how far the joystick travels to the right to keep it out of the regen mode."
bumper
sounds like it very well could be an issue with the regen function. That is a great explanation of what regen is. Sometimes I feel a little stupid about some of this stuff. It's why I ask here.
/ FEL question on G3038 #14
Me too. My B3350 has regen dump and I have the loader valve running a front snow blower in the winter. I soon learned about regen as the dump and curl circuit is used for the hydraulic motor to turn the chute. Works nicely once you figure it out :confused:
bumper
/ FEL question on G3038 #15
kjonfc
Some valves have regen in the first part of lever movement and others have it in the last part of lever travel.
When you shift the bucket lever to the right, you might be in regen at the gitgo, so do this test.
With the bucket flat on the ground, push the lever a little to the right and hold it to see if the bucket will curl down and lift the front wheels off the ground.
Now, push the lever to the far right and do the same test. Try and lift the front wheels off the ground.
Regen has less power, but will dump faster. You are feeding the base end of cyl, the pump flow plus the cyl flow, almost double the normal flow.
Non-regen is the power mode for curl down.
kjonfc
Ok, so I did the test last night and here's what I found. First, if I start with the lever slightly to the right just to where the bucket starts to move, very slowly, it will pick the front off the ground. If I curl it back and try it again with the lever all the way to the right, it still works only faster, but the test is not exactly all the way valid because if I dump and curl and dump and curl, the flop problem doesn't happen anyway. I'll have to try it again today after it's been sitting (I don't know how long before it'll do it again) and try the test with the lever all the way to the right the first time. I did notice that after I'd done the test initially and all seemed ok, when I raised it up and dumped, it would flop, but then the cylinder would catch up which it wasn't doing before. I'm thinking that the regen isn't working as it should. Or, is it possible that LS tractors don't have/use regen? Or is that just unheard of in tractors today?
/ FEL question on G3038 #17
If you are not far from your dealer go there and try on one of his tractors and talk to him it is new and I am sure he wants you happy.
I'm sure they do, they were great folks to deal with, the problem is, they are over an hour away. I'd take it to them just to see if it was a problem at all were it not for that.
/ FEL question on G3038 #19
Reread my post just you go try the dump on one of his tractors.
/ FEL question on G3038 #20
My dealer called yesterday. He said there's nothing wrong with it. The new ones on his lot do the same thing. I guess I'll just have to get used to it.
Eugene
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
(4) Dura Trench Drain Grates (A60463)
(4) Dura Trench...
Strickland MFG 24" Excavator Bucket (A60463)
Strickland MFG 24"...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
INSPECTION (A61166)
INSPECTION (A61166)
(3) 24"x20' PVC Pipe (A60463)
(3) 24"x20' PVC...
