Having problems with traction on your lawn tractor?
   / Having problems with traction on your lawn tractor? #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
I thought bar lugs would work for mowing my pool bank but not that well. So my latest caper was ATV lugs; independent lugs in an H pattern of about 2" square, randomly spaced around the tire. Got them off the www. My wheels were 7" wide and the tire 6.5 but once I got them mounted they are perfect, wet grass or not.
May be what you have been looking for too.
Mark
   / Having problems with traction on your lawn tractor? #2
Mark
I've waited a week already for someone to ask you for specifics and pictures. But no-one did. So... gimme, gimme, gimme! Yeah - I have the same problem. I do have a concern though that if TOO much traction, is flipping the mower over likely?
   / Having problems with traction on your lawn tractor? #3
Load the tires with WW fluid. The difference is unbelievable.
   / Having problems with traction on your lawn tractor? #4
I already have done that as well as adding 50# weights to each of the rear wheels.
   / Having problems with traction on your lawn tractor? #5
I have the bar lugs on my ZTR Craftsman and they hold pretty well except on wet grass with a hard dirt underneath. The problem is that they will dig a hole pretty quickly if you try to turn fast. I use it to mow the wet areas and it really powers thru mud and water. I think on a heavier mower it would work better. The Craftsman is just not heavy enough to get much traction on hard dirt. I don't know what it weighs specifically, but two boys lifted it and put it on my trailer when I bought it, you wont get 4 people to easily lift my Ferris @ 850# and it does fairly well in the traction except in mud where the turf tires just slick over.
   / Having problems with traction on your lawn tractor? #6
Mark
Knobbys. Good omni direction traction. - Lo tread area assures they penetrate and "grasp" the ground or any compliant surface well.
   / Having problems with traction on your lawn tractor? #7
Re: Having problems with traction on your lawn tractor? Nope!
Found two Ditch Witch wheels and R1 tires on craigslist and the TORO is 4x4!
   / Having problems with traction on your lawn tractor? #8
I think if you have weight and lug tires on it, you have done all you can with that machine. I guess you could try chains, but maybe you need a different machine.
   / Having problems with traction on your lawn tractor? #9
That is a distinct possibility.Depending on the degree of incline and the tractor.Wheelbase length,weight distribution,differential lock all factor in.This tractor is set up for a very steep hill up to 32 deg.Rear locker,8 ply dirt commanders filled,300 lbs of barbell weights on rear,45 lbs on front.Front end gets light but hasn't come up yet.Tractor weighs 845 lbs on the back,650 lbs on the front,dry.
Go the DR site and go to the pull behind mower section and pull up the pictures. Take a look at the tires they have mounted on that 44" self propelled mower. That is exactly the tire I have on my pool mower and are 6.5" wide, although I just found out DR uses them too a few minutes ago answering another question. Obviously they know they work too as they have them on their new mowers for sale.
I liked them so much I wanted a set for my 52" DR Versa-Pro Z which uses the 23x10x12, 4 ply. I found the CST 9309 Ambush Sport in that size and bought 2 from bikebandit.com. I just now pulled up the site and noticed they were on the first page now and the price had changed significantly from when I bought mine a couple of weeks ago. I just checked my bank account and I was charged $123.90 for a pair of these including shipping, receiving them in 2 business days. I was duly impressed with the product, price, and service.
They had a lot in stock at that time. Looks like a lot of folks jumped on the band wagon as there are only 2 left but at the price I paid for two. I guess the marketing software on their computer noticed they were selling fast and upped the price. Once you see the tread pattern that works, surely you can find another good deal like I got.
Main thing I found here is that you need the individual post on the ground to get the grip you need. My problem with bars wasn't weight, it was traction between the tire and the grass. Plus since the lugs were diagonal, there wasn't anything to stop sideways movement whereas the individual studs each have a gripping point. I was out yesterday with the DR mowing pool banks that I never attempted before and that sucker just walked up and down the bank.
On weight, the original pool mower I modified is the conventional single pump solid rear axle riding mower. Theme with it was light weight. With the tires on it, it does the job intended. On the DR I had added a lot of weight (to it's already (900#) out beyond the rear of the mower to counter balance the weight of the deck and all as it had too much weight on the front tires. But it is ZT and a different critter. So in this case, yes the ZT did have significant weight over the rears also. Do I need it? Don't know and right now I don't care as what I have works and that's what matters.
Edit: Locknuts pictures just popped up and obviously he has a solution too. Looks real nice. His tread pattern is maybe better than mine. Has more angles and all. Like I learned, you need the individual points of contact to get the traction.
Oh and on your question about roll over, the aspect ratio on my DR is wide and not very tall. If I rolled, it wouldn't be to the side as the rears are 53" across, it would have to be going over backwards. The weight I added out beyond the rear is not only a counter weight but can act as a backwards rollover stop also. On the original conversion, I just sit on the side of the seat and with this mower I go sideways, not up and down like I do with the DR. Not the least bit worried.
HTH,
Mark
71050 (A49346)
71050 (A49346)
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A51039)
2018 Rock Solid...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A51039)
Marliss Industries...
