boggen
Elite Member
- Joined
- Feb 22, 2011
- Messages
- 3,829
- Location
- Trivoli, IL
- Tractor
- SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
some prespective of what i have here on the farm....
i generally have projects that there are no way to bring to the shed/shop. were i would like to use air tools. including broken down tractor /truck with flat rear tires, or shingling a cabin roof, or something. because of needing stuff else were on farm. i have a small 3200w generator (barely able to manhandle, on the uglier days), a small air compressor 120psi max 7 gallon tank on it, a portable 5 gallon air tank.
i modified the portable air tank, so i can hook it inline, with air comrpessor.. other words.... generator -> air compressor -> short hose -> portable tank -> hose -> what ever tool i need. the portable tank, allows me to run some impact wrenchs long enough before my PSI goes down. or to run air nozzle to clean out a radiator / oil coolers on tractors.
the small air compressor has been used with chisel hammers on home to deal with knocking a hole in basement concrete block wall. to other...
i do have a second older small air compressor as well. that i sometimes TEE together. (so 2 air compressors and portable tank all connected together) to raise my CFM of air and overall volume of stored air pressure. to help run through some projects that demand the extra air. the 2nd air compressor pretty much stays connected and never moves out of the shop/shed.
with my luck, so happen so today, the second older small air compressor, the belt decided to come apart on me :/ thankfully i was able to complete the task with other air compressor. and there been a couple years back, when another air compressor also went bad, and having the backup kept me going on the given project.
budget still has not allowed it, to buy up a few hundred feet of air hose and more so fittings. to route air through the shed / shop area. and i dread the long 40 foot hose and the stinking mess it ends up getting into. "half time untangling it, vs using a given air tool" and because of that tend to have 3 to 4 short 5 to 10 feet hoses with swivel ends. half coil/spring type hoses, to half straight hoses. allowing me to mix and match. between dragging stuff to tractor / truck outside shed door "checking air pressure" to working air tools inside. impact wrenchs, air gun, sander, etc...
with above said, for my own shed/shop area. i would most likely be better served. with ceiling spools of air hose, that i can grab a hold of, and pull a few feet of air hose out as needed. so i am not tripping over the stuff constantly between air compressor and work site area. this also goes with electrical extension cords. other words my walls are cluttered with storage and storing of tools and my work space is in the center of it all.
