Oil & Fuel 5W20 instead of 5W30 in 2320...whoops
   / 5W20 instead of 5W30 in 2320...whoops #1
rocketjeremy
John Deere 2320
I was trying to do good today and get caught up on all the vehicle maintenance on the property, oil changes and the like. I just realized though sitting at dinner and making my list of supplies to have on hand I did my oil change on my 2320 using 5W-20 like I use on my trucks instead of 5W-30. Is it going to be big enough of a deal to change it out or should I be ok. I only have just shy of 100 hours on it and I live in eastern PA if that helps for the climate I will see this winter.
Thanks!!
   / 5W20 instead of 5W30 in 2320...whoops #2
I wouldn't worry about it, and expect it will lube your engine just fine. But if you are losing any sleep, change it out... :)
   / 5W20 instead of 5W30 in 2320...whoops #3
If it calls for 30wt use it. 20wt will let the bearing surfaces skim too close at operating temp and hi load.
   / 5W20 instead of 5W30 in 2320...whoops #4
If it calls for 30wt use it. 20wt will let the bearing surfaces skim too close at hi load.
That's what I'm thinking.
Price of another oil change -vs- price of an engine rebuild? No brainer.
   / 5W20 instead of 5W30 in 2320...whoops #5
Id be more worried if the oil has the correct api classification. diesel oils are not the same as oil for gas engines. This would likely cause far more damage than a light weight oil. I know automotive oems changed oil ratings from 10W30 to 5W30 and then 5W20 without making changes to the engines. This was done for fuel economy. Like others mentioned this will probably cause some additional wear but I would guess it would be minimal especially if its synthetic.
If your oil does not have one of these ratings drain it no questions asked.
API Service Classification CI-4, API Service Classification CH-4, or ACEA Specification E3.
Per john deere
Choose oil viscosity based on the expected air temperature range during the period between oil changes.
John Deere PLUS-50™ oil is recommended. John Deere TORQ-GARD SUPREME™ and oils meeting ACEA Specification E4/E5 may also be used.
Other oils may be used if they meet one or more of the following:
API Service
   / 5W20 instead of 5W30 in 2320...whoops #6
Absolutely.
   / 5W20 instead of 5W30 in 2320...whoops #7
With all the questions from owners about weight of oil, brand, synthetic vs straight mineral oil, etc., I wouldn't be surprised to learn than many of them are using motor oils for gasoline engines rather than diesel.
   / 5W20 instead of 5W30 in 2320...whoops #8
I would immediately change the oil to the correct oil. I use 15W40 Mobil diesel oil in my 2320 year around and would not consider using a lighter oil.
   / 5W20 instead of 5W30 in 2320...whoops #9
Per john deere
API Service
Xring100,,, Thank you for posting this information.. I had typed up the same type of reply last night, hit the wrong key and lost the post.. I was glad to see this info in your post.. It's true about the thinned out oil for fuel economy..
(CAFE),, corporate average fuel economy is a federal program imposing increasing fuel efficiency ratings.. None of the manufacturers can easily meet these guidelines, and it's costing a lot of money to try..
The first, fastest, and cheapest way for them to get closer to the requirements was across the board lighter oil weight recommendations... It has nothing to do with a new fangled engine, no such thing...
Some of the oils recommended now in the states, aren't for sale in any other countries,, yet the engines are the same...
I don't know if the original poster is ever coming back, but I recommend putting some real oil in the tractor and his truck too !
Lastly,, Machine Lubrication published a report a couple of months ago that reported fudging on stated weights. The report indicates that a large amount of tested oil is coming out thinner by actual weight than the posted weight on the can... I believe the report as it fits in with the other underlying changes mentioned above...
Now,, I don't follow the government,,, could care less about politics,, but I know one thing,, if the government gets involved in anything, it's going to be a mess,,, and they are a mile deep into engine oil at this time...
We are running 10w40 in our new cars,,, 15w40 in our diesels,,, 30 weight racing oil in our antiques..
   / 5W20 instead of 5W30 in 2320...whoops #10
Per john deere
John Deere PLUS-50 oil is recommended. John Deere TORQ-GARD SUPREME and oils meeting ACEA Specification E4/E5 may also be used.
API Service
Diesel rated oil handles soot better so the gas oil just will degrade faster.
,,, Too light an oil is very sensitive to any contaminant because the oil clearance in the load zone of the bearing is smaller. The hydrodynamic bearing requires viscosity and speed to keep the surfaces separated under load. An automotive gas engine operates at higher rpm and seldom sees heavy load at low rpm because if you want to move now the throttle and a downshift go together. On a governed engine the throttle advances automatically to hold speed. You only notice overload when it starts to bog. If youre running mid rpm on a diesel its going pretty slow but with max torque available via the governor. I would never consider using 20wt in a tractor diesel except in the winter. I dont think you will find any mfg recommending a 20wt in a temperate climate.
larry
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
