tractor with no thermostat?!
   / tractor with no thermostat?! #81
You're all engineers. Let the poor sole fix his tractor and be done with it.
Fred
   / tractor with no thermostat?! #82
Fred
Well thanks but I have to disappoint you. I aren't an Engineer, just an old farm boy who spent his life off the farm doing as the boss told.
   / tractor with no thermostat?! #83
All this arguing about turbulence & flow restriction & temp readings is ridiculous and it's turning this thread into an unrecognizable mess. Virginia Joe needs to check his timing before he can move on to the next step. Why don't we all leave our egos at the door until he does that so we can actually help the guy, hmmm? :rolleyes:
   / tractor with no thermostat?! #85
Fred
If you are not qualified to do your dentistry. Do you go to the internet for advice before drilling cavities? If dude is in over his head with "over heating. He is going to spend a lot of time and money while possible making things worse.
   / tractor with no thermostat?! #86
It costs nothing to check the timing and look under the distributor cap to see if the centrifugal advance is free and operating properly. ;)
The whole point of proper step-by-step diagnostic procedure is to avoid unnecessary spending. Jumping around randomly replacing parts that may or may not be needed wastes time and money.
if you want to get mired in an endless over-complicated 'discussion' about physics and mechanical theory, talk to an engineer. If you want to get something fixed, talk to a mechanic. :p :laughing:
Virginia Joe - anything to report? :confused:
   / tractor with no thermostat?! #87
if you want to get mired in an endless over-complicated 'discussion' about physics and mechanical theory, talk to an engineer. If you want to get something fixed, talk to a mechanic. :p :laughing: ... :rolleyes:Then, if you find the mechanic flailing, see the engineer to find out what he should have done.
Ditto VJ :confused2:
   / tractor with no thermostat?! #89
Y'know, if engineers were forced to wrench on their own design prototypes before they went into production, the mechanic's job would be a thousand times easier. ;)
Now that I think about it, I reckon us mechanics have ya'll engineers to thank for our job security. So... thanks a lot. :rolleyes:
:p :dance1: :laughing:
   / tractor with no thermostat?! #90
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
1985 International X Con Semi (A50514)
1985 International...
66in Light Material Bucket Skid Steer Connection (A52128)
66in Light...
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2019 BOBCAT S770 SKID STEER (A51242)
2019 BOBCAT S770...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
