LD1
Epic Contributor
It sounds like something weird may be going on with that thermometer. I would think the thermometer should have read hotter than 100*.
What were you doing with the tractor when it you got 203 on the block?
Ir guns dont do well on reflective surfaces. The duller the better. And the darker the better too.
They also dont do well measuring water temp as water is clear and the shiny bottom of the pan will likely give false readings too.
They are good for comparing things though. like if you have shiny headers and trying to find what cylinder is missing, while not accurate temperature wise, accurate for comparing what one is running cooler.
