John Deere 5420 Cab, no air on right side
   / John Deere 5420 Cab, no air on right side #1
shearpin
Dade City, Florida
John Deere 5420, IH 656, Farmall 100, Mahindra 6500
John Deere 5420 Cab, air conditioner has no air coming out the right side vents. Left side working fine. Removed top covers and found both left & right motors running fine. Could not see anything that would prevent air flow on the right side. Any suggestion as to what might be blocking the air flow only on the right side and how to access it to fix the problem?
   / John Deere 5420 Cab, no air on right side #2
I'd suggest to raise cab roof,remove cover(parts key 1) and see where the problem is. Does your tractor have a window defrost setting?
I remove the top. Although I could see the fan turning, I remove the motor anyway. That痴 when I found the obstruction. Reassembled working fine. Tractor was purchased used in Sept 2013 with 749 hours, thinking I would have to replace a few parts fan motor or relays. Turns out only had to fix someone else痴 careless mistake.
Thanks for your time and suggestion.
40ft Shipping Container (A49461)
40ft Shipping...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
Bucket 12 Inch (A50322)
Bucket 12 Inch...
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
