OK ... Here's a question for ya!
/ OK ... Here's a question for ya! #1
Mendonsy
Mendon, NY
Kubota B7500HST/LA302
I went out to use my B7500 this week after it had been sitting outside for about a month without being used. It started right up but died a couple minutes later. I ended up having to drain about a pint of water out of the fuel tank to get it running again.
Soooo ... the question is how could that much water get into the fuel from just sitting????
This summer in the Northeast has been cold and wet, so I can see some condensation getting in there but with a 5 gallon tank that was more than 3/4 full it doesn't seem like it could be that much. The factory cap was on and tight so I don't see that being a possibility either. The tractor had been run several times the last re-fuel so it doesn't seem like there could have been water in the fuel.
Anybody got any good ideas???
/ OK ... Here's a question for ya! #2
I don't know what to tell you. My tractors are all under an open on 2 sides shed and I have never had any condensation in the fuel issues.
/ OK ... Here's a question for ya! #3
Same here, but all my tractors have always been under cover of some kind thru the years, and I have never had a water issue. Maybe you have a crack in the tank? I don't know that to suggest.
/ OK ... Here's a question for ya! #4
Vandalism?
- Jay
/ OK ... Here's a question for ya! #5
My tractor is always parked in a shed except when in use. Never had a water problem either. I had a water problem with a vehicle in Anchorage, AK, over one winter. Outside parked at work all day - heated garage all night. In the spring I drained a little less than a quart out of 14 gallon gas tank. Condensation. I've always kept all my vehicle fuel tank full since that time.
/ OK ... Here's a question for ya! #6
Condensation is one, surprising how much you can get. Water in the fuel as supplied is another. I am going to change the water block filter out of my supply tank for the second time this year, water that is either in the fuel from our supplier or is from condensation in the tank.
/ OK ... Here's a question for ya! #7
Vandalism?
- Jay
I was thinking the same thing, there's NO way that much water could get into the tank.
"IF" the cap was on "tight' as the OP said.
/ OK ... Here's a question for ya! #8
I always use fuel conditioner plus a "stabil" type additive year round. So far in many years I have not had a water problem.
/ OK ... Here's a question for ya! #9
Get some ,"new" fuel and poor it into a 2=liter pop bottle and see what you actually bought. Have you run over anyones Dog lately? Never got that much water on any equipment without someones help.
/ OK ... Here's a question for ya! #10
After all winter in the wet northwest I can get maybe 1/4 teaspoon of water. I say sabotage as well unless you bought some bad fuel recently. No way that is condensation.
/ OK ... Here's a question for ya! #11
Yep... no way that much water from condensation. Something else, like bad gas or vandalism are likely candidates as others have suggested. In any case, flush the tank and start with fresh. Maybe change your source for fuel?
Wolverine MCB-11-48W Mini Skid Steer Bucket (A62679)
Wolverine...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
