IH Cub 782 Need engine replacement
/ IH Cub 782 Need engine replacement #1
rdc127@comcast.net
Kensington, NH
IH CC 782
I need to replace original Kohler KT17 twin in my CC 782. During last snowstorm, I was blowing more oil & smoke than I was blowing away snow, as well as had no power. I had blown head gasket some years back when engine overheaded due to some undetected field mice nesting in the cooling fins.The engine s/n is 11006361 and the chassis s/n is 2050594 U688998. I live in southern NH.
Local MA dealer told me to sit down before he quoted $3900 for new short block or $4500 full replacement. Ouch! That's more than I've spent on my last two cars.Then dealer started the sales pitch for a new tractor. The new rigs just don't appear as robust as the earlier models (have that Sears & Roebuck look).
The 782 tractor is in decent shape, little duck tape on the seat. I have already invested some money on other parts over the years. I really want to keep the unit. I'm no mechanic so I'll need someone to do the work. What are my options? Any good used or rebuilt engines out there? Or plug in replacements? What do you recomend? Thanks for your help.
/ IH Cub 782 Need engine replacement #3
There are a couple of repower "kits" out there for the 782 if you want a brand new engine, one uses a Honda and other is a Briggs Vanguard, both run around 1600 for the kit. If you want to go with a good used power plant, like a Kohler Mag18, check out the ihregistry.com website. Join up, its free, and email member Ray Weaver, he lives in eastern pa and has hundreds of cub cadets he is parting. He can get you a good engine for alot less. Most depends if you can do your own work swaping out the engine. There are loads of great guys and gals on the ihregistry website. Its dedicated to the cub cadets and keepin them running. I have helped a few guys repower thier tractors or overhaul the engine. PM me if you need to know more or want to talk on the phone. Mike
Thanks to Rocks and Mike for quick response. You've pointed me in the right direction. I'll get on them and see what options arise. I'll keep you posted on my progress. Appreciate the offer to call & discuss. Stay tuned. Rich
/ IH Cub 782 Need engine replacement #5
That dealer is a joker. A brand new KT17 Series II is available for the 782 for $1900 from Small Engine Warehouse. They also have 2 Honda kits for the tractor, 20 and 24 HP, for $1600 and $1800. The Hondas are conversion kits, the KT17SII an exact replacement. A re-engined 782 will probably still last longer than anything new the dealer could try to sell you.
-Fordlords-
Thanks Fordlords, great info.I like the new approach for the long term. I found some used units but i'd rather not roll the dice. I'm going for the KT.
I spent my high school days in Lakewood, NY by Chatauqua(sp?) Lake, near Jamestown. Went to Grove City College. I gave up those daily snow squalls for the big New England Noreasters. Enjoyed many a day on the slopes of Holiday Valley. I miss driving the interstate 90 headed for a Cleveland Brown's game to watch Jim Brown and having my 67VW bug get blown over 4' by the gale winds howling off the lake....and all those whiteouts...take care.
/ IH Cub 782 Need engine replacement #7
I'd go with the honda transplant!
/ IH Cub 782 Need engine replacement #9
I have had no trouble with the Honda, it works excellent in the tractor and I would do it again. I have no real gripes with Series II KT17's, other than it does not come with an oil filter. The provisions are on the block, and you need to get the kit to use the remotely mounted oil filter, which I highly recommend for the SII, or any engine costing the amount of money these things do. Either way, a good 782 is well worth the efforts to keep running.
-Fordlords-
/ IH Cub 782 Need engine replacement #10
If it were me I'd spend the dough and rebuild the 782...that was an excellent tractor.
/ IH Cub 782 Need engine replacement #11
A new KT17 would be awsome, and definatly put the remote filter on it, Then run a 10w30 oil in it. Once you go to a filtered engine, Kohler and the others recomend a multi weight oil with detergent to trap the crud and take it to the filter. Mike
Just received my 782 back with new KT17 engine installed. Whoaa! Purrs like a tiger and what power. Obviously did not have much compression in the old one. I'm almost wishing for a huge one last big noreaster to dump some 24" of snow to give that snowthrower a whirl before putting it away for the season (had to shovel last week's 14" and I'm still sore). Not going to miss the smoking exhaust though it helped keep the mosquitoes down mowing later in the easly evening........Should I salvage any parts from the old unit or just leave the entire engine with the mechanic who changed it out? ..........What is involved with installing the remote filter? Makes sense. Something I can can handle without much trouble?
/ IH Cub 782 Need engine replacement #14
Congrats on the new engine! There is not much to installing the remote filter kit. It's 2 hoses and the mounting/filter. The kit comes with instructions that tell you which hose to put where. You can put the mounting/filter on the tractor's firewall. It's well worth the money. With that and regular oil changes and keeping the cooling air screen and air filter clean, a KT17 SII should run 2000+ hours as opposed to the 500-600 or so hours a series I would typically see before sinking- which BTW is about all the old engine is good for... a boat anchor :)
-Fordlords-
/ IH Cub 782 Need engine replacement #15
-Fordlords-
please tell me where to purchase the honda engine. does it come with conversion parts or do you have to field fit
/ IH Cub 782 Need engine replacement #17
-Fordlords-
Small Engine Warehouse: Home - Small Engine Warehouse
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
THE MACHINE CO. THAWZALL H250 HEATER TRAILER (INOPERABLE) (A67714)
THE MACHINE CO...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
2003 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2003 INTERNATIONAL...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
