2003 Yanmar Vio27-2 Left driver slow
   / 2003 Yanmar Vio27-2 Left driver slow #1
x19m3
Sacramento, CA
Yanmar Vio 27-2
Hello everyone,
I have a 2003 Yanmar vio27-2 that the left driver is slow and with no power only when goes back. When goes forward is fine. I did replace the hydraulic fluid and filter already but no luke.
Hope somebody can help.
   / 2003 Yanmar Vio27-2 Left driver slow #3
How many hours. Sounds like a drive motor issue, gears or motor failure
Hours 4400. But if is the drive motor it should do the problem on both directions ( forward and back)? It works fine in forward direction.
   / 2003 Yanmar Vio27-2 Left driver slow #5
I don't claim to be a mechanic , but just because it works fine doesn't mean it is ok. Could be having a problem in final drive that only binds in one direction.
I have run heavy equipment most of my life. Been on several excavators that tram fine in one direction but not in the other, always associated with drive motor or final drive. Good luck hopefully something as simple as dirt in drive motor workings.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2008 PETERBILT 367 FLAT TOP SLEEPER (INOPERABLE) (A55745)
2008 PETERBILT 367...
2008 OSHKOSH FRONT DISCHARGE AWD CONCRETE TRUCK (A56129)
2008 OSHKOSH FRONT...
New/Unused CFG Industrial MX15RX Mini Excavator (A54865)
New/Unused CFG...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2008 GMC C5 (A53422)
