What is this on the dash? (IH 300 Utility 1956)
   / What is this on the dash? (IH 300 Utility 1956) #11
You're looking at the wrong spot. The thing in question is below the steering wheel, right above the battery. I was convinced that it was a lighter without the knob, but on your picture, it also has no knob. So I reckon that ain't it. I'm now convinced it has something to do with the dewobbleizer.
Glo-plug indicator seems right. Had you asked 50 years ago, I could have told you exactly what it was.
   / What is this on the dash? (IH 300 Utility 1956) #12
jim44: actually on the pic, below the steering wheel on the dash you'll notice a gauge on the spot in question. perhaps this is another series of the model. i do think (if it's a diesel) that it is in fact a glo indicator good point :)
   / What is this on the dash? (IH 300 Utility 1956) #13
just look behind the dash and see what is hooked up. once you see what is hooked up.. it's function will become much clearer!
I think after looking at the CASE IH parts store, it looks like it was a cigarette lighter with the knob missing.
It is a gas engine. I will look behind the dash.
   / What is this on the dash? (IH 300 Utility 1956) #15
Yes IIRC I have seen some with a lighter there an it was an option.
   / What is this on the dash? (IH 300 Utility 1956) #16
I believe it is a lighter with the handle missing.
Those tractors did not have glow plugs. If they were diesel, they started on gas to warm up. After the engine warmed up, you moved a lever to switch it over to diesel.
   / What is this on the dash? (IH 300 Utility 1956) #17
An International 300 had no diesel option. If it were a 350 Diesel it would have had a Continental Diesel which was not one of the IH start-em-on gas-try-em- on -Diesel engines.
   / What is this on the dash? (IH 300 Utility 1956) #18
All you guys saying it's a cigarette lighter module less the knob are correct. How do I know? back when I smoked I took one off (it's handle) and replaced it when it quit working.
Mark
   / What is this on the dash? (IH 300 Utility 1956) #19
Thank you for the correction Rick.
   / What is this on the dash? (IH 300 Utility 1956) #20
Actually we are all wrong. I just remembered it's a cigar lighter and that's why it is the diameter it is. Somebody said that years ago. Forget the origin but it made sense. But since most folks smoked cigarettes, not cigars, it was commonly known incorrectly as a cigarette lighter.
So much for today's trivia.
Mark
2019 John Deere 1025R 24HP 4x4 Loader Utility Tractor (A55973)
2019 John Deere...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
Massey Ferguson 3pt 5 Bottom Plow (A56469)
Massey Ferguson...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
UNUSED FUTURE MINI EXCAVATOR (8) PC ATTACHMENT SET (A57193)
UNUSED FUTURE MINI...
UNUSED FUTURE CAT 305 EXCAVATOR AUGER DRILL (A57193)
UNUSED FUTURE CAT...
