OP
rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 12,188
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
One thing I've been pondering on was attachment and removal of the snowblower on the loader ... particularly how making hydraulic connections would figure into that. The pump will be located roughly under the operators station and will be installed on the tractor for the snowblower only in winter. I'd like to be able to disconnect the hydraulic lines at the pump (ideal) or at the blower (ok I suppose, but less than ideal)
I realize that the ideal situation is to keep the fluid flowing as freely as possible ... and that hydraulic quick couplers can impose some restriction, with ISO 16028 Skid Steer quick couplers probably being the least restrictive ...
Seems like the suction line/supply/feed to the pump would be the place where the least restriction would be desired. With that in mind, does anyone know if "wet line" quick couplers like the ones at the link below are less restrictive than the ISO 16028 Skid Steer type ?
Wet line Coupler, Dry Break Couping, Hydraulic Quick Disconnects
I was thinking either an ISO 16028 Skid Steer coupler on the pressure side (3/4) and wet line on the suction/supply side (1 1/2) ... or maybe wet line for both ...
