ruffdog
Super Star Member
- Joined
- Dec 31, 2011
- Messages
- 10,677
- Location
- southern wisconsin
- Tractor
- Bobcat Toolcat 5610G, Deere X744, Cub Cadet IH 982
As sld mentioned, the block is not cast iron. It is CGI - Compacted Graphite Iron.
I don't recall thrown rods being a big issue with the 3.5L EB. Like your cast iron block comment, I'm sure you were just misinformed and you thought you had to relay that bit of misinformation here to attempt to make a point. Besides, the 3.5L EB will carry on in the F150, mostly the same as it is today.
Maybe you should frequent the EB forums more if your not seeing the blocks vented by a busted rod. You are misinformed when you said the EB only has a minor CAC problem. When the CAC sends a load of water sludge on top of a piston, it may hydro-lock and bend or break a rod. A tad bit more than a minor problem.
Even the F150 forums turn into a EB is better than anyone else's truck including fords own 5.0. It just gets tiring and the propaganda keeps getting more flamboyant.
