Rotary cutter / "position control"
/ Rotary cutter / "position control"
"..Normally the slip clutch stays with the rotary cutter,/PTO shaft. the slip clutch usually has half of a PTO yoke on one end and a 1 3/8 splined female fitting on the other. But for some reason, they removed the slip clutch and found an old PTO shaft with 1 3/8 on both ends and put it on, or something similar. In any case you don't have any protection. so if you hit something immovable, something is going to break. It could be PTO components in your tractor..."
I am thinking that the slip clutch was probably like this one, with male/female splines:
FD1 PTO Slip Clutch-1-3/8 In. 6 Spline | Agri Supply #31951
....and it would have been on the tractor rather than on the cutter (it would fit either place) and whoever left it on the tractor just did not know any better,
just like probably the same person left the top link on the angle blade. I can't see anyone going to the trouble of switching out PTO shafts just to get the clutch.
Regardless, agreed that I need something in the driveline, and the link above is probably the best & easiest solution.
....and it would have been on the tractor rather than on the cutter (it would fit either place) and whoever left it on the tractor just did not know any better, just like probably the same person left the top link on the angle blade. I can't see anyone going to the trouble of switching out PTO shafts just to get the clutch.
/ Rotary cutter / "position control" #23
You are probably right. I reckon that one would work for you.
/ Rotary cutter / "position control" #24
I am not seeing the compbination over-running coupler/slip clutch @ ASC, but did see this, which would be an easy (but not real cheap) fix:
Easier to install than replacing a unversal joint yoke. And, if it should turn out that the PTO shaft has been shortened to the extent that it is now too short for my aplication, the slip clutch might solve another problem.
Ax8-1210 W/ Fd4 Slip Clutch 8212831 Pto Shaft By Eurocardan
/ Rotary cutter / "position control" #25
This is a photo of just one end, but both ends of the shaft are identical:
In fact, I am not sure which end is supposed to be the tractor end, and which end is the cutter end. The cutter gearbox has a splined input shaft identical to the PTO output shaft of the tractor. The cutter gear box input shaft is not smooth.
Neither end yoke on the shaft is set-up for a shear bolt, in the manner that this yoke is:
1486037 6 Lc6 Shear Pin Flange Yoke
This is for a non-shear device application like is on my tedder and on my Cosmo spreader. Both ends are the same so the only question is do you leave it outside in the weather? If so rotate the shaft such that the outer sleeve is up when stored thus keeping water out of the sliding parts.
Mark
16 FOOT TRASH TRAILER (A67714)
16 FOOT TRASH...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2011 MERTZ BLENDER TRAILER (A67714)
2011 MERTZ BLENDER...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2015 Freightliner (A64119)
2015 Freightliner...
GAYLEAN  130BBL VACUUM TRAILER (A67714)
GAYLEAN 130BBL...
