Kubota L4200 value / life expectancy
/ Kubota L4200 value / life expectancy #1
rootex
I've found a used L4200 4x4, with a loader, LA 680, with 2300 hrs at $12.5K and was wondering if this was a good value. It has the wide turfs on the back. Owner claims to have had it serviced regularly.
What kind of life span can one expect out of it with proper maintenance? Is there a recommended overhaul time? My dad and I would be doing light landscaping, gardening, and mowing 5-10 acres.
Thank You
It's a 1998
/ Kubota L4200 value / life expectancy #3
that tractor could last 20yrs more if maintained right.our oldest tractor is 36yrs old and its still running.and it has close to 15000hrs on it.12000hrs on the 2nd motor as the 1st 1 blew early.
/ Kubota L4200 value / life expectancy #4
Thank You
Rear remotes?
Canopy?
Tire quality?
How do the hoses look?
Does he have the shop and parts manuals?
Price sounds fair.
In January 2013 I paid $12K+ tax etc. for this M4700
It has 2 rear factory remotes, 1400 hrs, needed 2 front tires and about 4 hoses. The rear tire still had the "nubbies" on them. Came with all the manuals.
/ Kubota L4200 value / life expectancy #5
How does the tractor look in person? Does it look like it's been well maintained as the current owner claims? You can usually take a few mins of walking around a tractor and running it for a min and tell what kind of shape it's in. I will say that I'm a lot more comfortable buying a used tractor then I am a used car. I've seen tractors with only 700 hours that I wouldn't touch with a ten foot pole and seen some with 4000 hours that I wished I woulda jumped on and regret letting them pass me by.
No rear remotes or canopy,
Hoses look very good, didn't ask if they'd been replaced but saw very little cracking
Rear industrial turf tires I'd estimate at 50%' front turfs at 75%
The tractor looks in very good condition. I'd have guessed it was a 500 hour machine.
Anything else I should look over besides leaks, general condition, and a better look at hoses.
I was unable to operate it as the owner wasn't around at the time I viewed it.
/ Kubota L4200 value / life expectancy #7
I'm guessing it served as a golf course tractor at one point in its life or a sod farm. Is he the original owner?
He is the original owner, and it was a sod farm tractor. They got out of the business. How'd you guess that? The industrial turfs?
/ Kubota L4200 value / life expectancy #9
You need to decide if those turf tires will work for your intended uses of the tractor. If they won't, you can sink a lot of money into replacement tires/wheels, which can make a good deal into a not-so-good deal.
/ Kubota L4200 value / life expectancy #10
Yes - you should price out tires if they are 50%. If you decide to switch to an Ag tire/wheel set it might cost a grand or two.
/ Kubota L4200 value / life expectancy #11
Sod farms are popping up around here and I know what types of tractors they use. With the information you gave about the tractor I would pull the trigger if you like what you see and it drives good. Those sod farm tractors usually have high hours but it's not from hard use, they'll pull those batwing flail type mowers over grass that looks like a big lawn. They get used weekly but they're also usually kept up well.
/ Kubota L4200 value / life expectancy #12
On second thought that tractor may not have been used to mow but perhaps spent its life loading sod pallets onto trucks. The reason I guess that is because you said it had a loader and doesn't have a canopy. Those tractors that are used for mowing typically have a canopy and very rarely have loaders on them. That still wouldn't bother me none though.
Thanks for the info guys. I do think that the tires will work for our application as it'll be used mostly on turf, once I get about 2 tri-axles of sand spread and 2 of black dirt, it'll be used mostly to mow our runway, looking for one of those bat wings mowers as well. and it'll till the big garden each year.
Thanks again for the info quick replies.
/ Kubota L4200 value / life expectancy #15
Too much money. Closer to $9-10k would be more like it. I bought my L4200 (1994) with just over 2000 hours on it with a fairly beat up 9' Woods backhoe and an almost new 16' equipment trailer for $15,000 in 2007. The PO paid $21k for the setup two years earlier from a dealer, but he got porked, IMHO. The machine had fair condition turfs and was in good shape for the hours, although the loader was fairly worn and the seat needed replacement. It was plumbed only with power beyond for the backhoe with no additional remotes. The only issue were the control arm ball joints were shot, so I changed out the arms (~$200) and the starter crapped out a couple of years ago, so I changed that too for ~$200. I ended up re-plumbing the hydraulics so I could run external remotes with the 3pt or PB for the backhoe. I also added a roof, front and rear work lights, added a big fat glow-plug bypass button, and made a new cutting edge for the loader last year out of an old town plow blade. I never did replace the seat, so it is absolutely atrocious now... :) OTOH, my L4200 now has close to 2700 hours and still runs like the day it rolled off the lot.
Thanks again, unfortunately it sold. Found another on craigslist, but it looks a little rougher, with lower hours and at $11.5k. May take a look at it tomorrow.
