Oil & Fuel L2900 Hydro Filter Change
/ L2900 Hydro Filter Change #1
BackwoodsMan
Macungie, Pennsylvania
Kubota L2900
The hydro filter on my L2900 reached a 200 hr interval so I purchased a new filter at my Kubota dealer for $33.84 and proceeded to change it. The manual said a small amount of fluid will need to be replaced. When I removed the old filter, fluid kept draining. I quickly screwed the new filter on, but 2 gallons of fluid drained and more would have if I didn't screw the new filter on. Did I miss a step or a way to prevent this draining. I ended up adding another $40. worth of new super UDT because I didn't want to put back the drained oil.
/ L2900 Hydro Filter Change #2
No you did fine. The filter on the 2900 is right at the suction point of the hydraulic pump, and will continue to drain the tank without the filter on. Just need to be quick. Have done lots of those.
/ L2900 Hydro Filter Change #3
A trick I've seen on tbn is to use a vacuum in your fill hole. That prevents the drain out and won't suck fluid in your vacuum either. You still lose some but ounces instead of gallons.
/ L2900 Hydro Filter Change #4
Yup heres unrelated thread where some of us used shop vac vacuum to keep from loseing hydro fluid.
http://www.tractorbynet.com/forums/...pacity-l3400.html?highlight=kubota+l3400+lift
Learned it here on TBN also. Another thing I've done is ride up on planks an leave tractor leaning on opposite side of filter and taken it off quickly to avoid much fluid loss.
CAT 225BLC Excavator (A65579)
CAT 225BLC...
10ft Cultivator (A65579)
10ft Cultivator...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
MIXING BUCKET (A62613)
John Deere 772-A Grader (A62679)
John Deere 772-A...
