Plow vs Disc
/ Plow vs Disc #1
Draagyn
Woodpecker, Canada
65 JD 3020, 75 IH 966
I need to re-establish my hay field. I have a JD 3020 gas with synchro range and wondering if I should pull discs or a plow. And what size of each would fit my tractor good without working it to the max.
How do finishing discs work as breaking discs? I don't see many breaking discs in my area...
I plan to re seed with my fertilizer broadcast spreader, what will I need to go along with it? Harrows? Finish disc?
Main problem with my field is weeds and dead spots from a freeze thaw freeze that happened last winter
/ Plow vs Disc #2
I hit fields like that with a chisel plow. Then a disk pulling a large drag to finish the ground. seems to break the compaction up and give seed room for deeper roots.
/ Plow vs Disc #3
I would spray with Round-up or equivalent, plow, disc then drag. Broadcast your seed then cultipack for the best results. Good soil contact helps greatly with germination.
I also like the chisel plow and a rough estimate is 10 hp per tine. Fracturing the soil is a great way to promote deep root growth. I have an 88 hp tractor and my seven tine chisel plow can be a load.
Minimum I would spray, disc, drag, seed and drag again if you are light on equipment and/or cash. (Who isn't?)
Good luck!
/ Plow vs Disc #4
We used to renovate our hay ground as follows:
Plow about 8" deep
Disc
Disc again pulling spike tooth harrow
Seed with Brillion cultipacker seeder
We have a 2550 Deere (65 hp) which is very similar in size to your 3020. A 16" three bottom plow is what we use and its a nice match for the tractor. We pull a 12' tandem disc and a 15' spike tooth harrow. The Brillion cultipacker seeder is a 12' working width. If you want to kill the stand with herbicide (we never did) you could get by with just discing, although you'd probably want an offset disc instead of a tandem disc for heavy tillage like that. I've never used an offset disc, someone else could better give you a size recommendation, but you'll probably only be able to pull a 7-8' offset disc (they pull much harder than a tandem disc.) Hope some of this info helps.
/ Plow vs Disc #5
Did you have livestock in the pasture, so the ground is really hard?
If so, either a Chisel Plow or a Moldboard Plow should be your first step.
A Chisel Plow may allow you to keep the grass roots you have now.
A Disc Harrow, whether offset or 3-Pt. tandem, will not work the ground deep enough.
A soil test is essential. Adding nutrients, including micro-nutrients, will make your pasture more productive for years at a small cost.
Investigate latest pasture grass. New varieties are much more productive than older varieties, but most improved varieties require some fertilization.
VERTICALTRX has the work order right:
Plow in Fall. Let sit over Winter.
Disc in Spring. Fertilize according to soil test. Disc again.
Drag
Sow
Firm soil and seeds together with a Cultipacker.
/ Plow vs Disc #6
Do you need to cultivate to level the paddock? If not would a contractor with a direct drill be an option?
Why did the grass die in that area, is it water logged, causing the freezeing? If so then you may need to look at drainage first.
/ Plow vs Disc #7
What kind of hay--grass, grain, alfalfa?
How thick is your good topsoil? That will tell you whether to use a moldboard plow, chisel plow or do primary tillage with an offset disc. Around here the topsoil is thin (4-5 inches) so grass and grain hayfields are prepared with an offset disc/spike harrow combination.
Alfalfa is a different story. Below the topsoil is hardpan that has to be fractured so the alfalfa can root properly (it's a perennial). That means ripping the soil to a depth of 24-36 inches using Cats with single or double shank subsoilers.
/ Plow vs Disc #8
Drag
Sow
In the mid-Atlantic region we always did our reseeding in the fall, around September. We also would do the whole process in a matter of a couple days. Never fall plow and leave the soil 'open' over the winter, this is a good way to loose all your topsoil to erosion. That was common practice 60yrs ago but most farmers have wised up since then, or gone no-till.
Speaking of no-till we also used to do quite a bit of that. We were basically just over-seeding and never killed off the stand first, but if you get everything just right it will take well and really thicken up the stand. We used a Lilliston 9670 no-till sod drill, I think it has about a 7-8' working width. The one we use is a little heavier than most, and a different animal all together than a drill like you'd drill beans or small grains with. Around here the local Soils Conservation office will often rent drills for over seeding pastures, I would guess there is something similar in Canada.
/ Plow vs Disc #9
I agree with the chisel (2") or something like a Hay King brand pasture renovator first, then a disc harrow or disc offset (better yet), and then a spring fingered harrow.
I have Houston Black Clay and even annually worked, in the fall, when it's hot and dry, it's rock hard. For the chisel I have a 7 shank drag type Haeme (Graham-Haeme Plow Co. Amarillo, TX.). Best working "rock" buster I ever used, with 2" chisels. I run it slow with 57 pto hp. Considering I take it slow to give the shanks time to work properly, I run it in the lower 1/3 of my shifting range so it probably equates to 10 hp/shank that a person would be working in midrange gearing.
Also, after all these years I bought a cultipactor a couple of years ago and the hay crop I got this year was partly due to compression of the soil after planting for proper soil-seed contact as Mr. Verticaltrx said. I had germination start in 4 days. I just keep learning. Every year for me is another experience.
HTH,
Mark
/ Plow vs Disc #11
I'm with Kioskcarp and Texasmark
Here's the HayKing renovator chisel plow and the Tarzan chain link drag harrow that I use.
Perfect. I bookmarked the pages so next time someone asks I too can show the specs. On the harrow, mine is a different brand but is of the same design. It originally had a pipe at both ends whereby you could drag it with the spikes leading or lagging. I found that I run it with them lagging and the extra pipe loads up with dirt so I took the one on the rear off and it does better. I noticed this brand already didn't have the rear pipe.
On the 5 1/2 " claim on the renovator I don't know where they get that number. I run mine a lot deeper than that with the coulter hubs at ground level and the rear of the unit tilted back. I have the 4 shank and on really rough ground make 2 passes with the second centered between the cuts on the first. Works great.
Thanks,
Mark
/ Plow vs Disc
Thanks everyone for all the info! So much! Been real busy, will take a bit to get back to y'all. For now I will say I need to do this on the cheap. I just geared up for haying this year, tractor, baler, mower , rake, and TONS of maintence and upgrades. Im so short on time and money that some days it's more stressful than fun. If I'd known the hay would be this bad I'd geared up for breaking not haying, such as life.
I'm game for making a small difference this year and then hitting it harder next year.
Will be back again soon.
Thanks again
/ Plow vs Disc
So my first step after cutting hay should be spraying the weeds?
I'll have about a month of growth after cutting. How long after spraying should I start till and seed process?
/ Plow vs Disc #16
Are you burning everything you can down with Glyphosate ?
/ Plow vs Disc
Thanks! Great info
So you're saying that just tilling alone will get rid of the weeds? As good as spraying would? What prevents the weeds from coming back, strong grass growth? keep in mind some spots are more weed than grass.
Timothy brohm mix is target crop.
I would say the good top soil would be no more than 4-5 inches. We are on solid clay and when i dig post holes its nothing but that after only a few inches.
/ Plow vs Disc #19
I plan on finding a product at local co-op to kill off the weeds and wild flowers and leave the grasses be
IMHO that isn't practical, especially if you are going to plow/disc the entire field. I would shoot the whole field with Round-up.
You still need to address your standing water that caused your problem in the first place. Given the depth of your top soil, I would run a subsoiler in the areas where you have the standing water problem so it would drain in the future.
With only 4-5 inches of top soil, discing is all you really need to do, just remember that you will be exposing dormant weed seed. The good news is grasses grow better in the late summer/early fall than weeds do. DON'T wait until spring to plant, you will be dealing with a whole new crop of weeds.
Good luck!
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
GREAT PLAINS 2400 TURBO CHOPPER (A64278)
GREAT PLAINS 2400...
500 GALLON FUEL TANK (A64278)
500 GALLON FUEL...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2011 International DuraStar 4400 18ft. Cab and Chassis Truck (A64194)
2011 International...
2017 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2017 PETERBILT 579...
