Pulled the trigger on a new RTV X 1100 CAMO
   / Pulled the trigger on a new RTV X 1100 CAMO
It's almost done still needs the rest of the items installed but the wheels make it look awesome already check it out
   / Pulled the trigger on a new RTV X 1100 CAMO #14
Looks good!
Please be sure to let us know how those tires wear. I will be replacing my original work site tires in the next 200 hours, they will have at least 1,150 hours on them by then. I have been eyeing some tires that look very similar.
I will keep you posted. The tires are made by journey P350 they are a maxxis bighorn knock off. 27x10x12 my buddy has them on his 1100 also and the have wore good so far about 200 hrs and still like new time will tell can't wait till Friday come on get here!!!
   / Pulled the trigger on a new RTV X 1100 CAMO #16
Thank you Sir.
   / Pulled the trigger on a new RTV X 1100 CAMO #17
sweet looking machine do you know if they went with the same size tire in front or are they the 27 x 8x 12 or maybe 9s I need to order a new one soon will get the same setup as yours just not all the add-ons
The tires are same size all the way around 27x10x12
Brought her home today what a sweet!!! Ride she is. Love the v plow here are some pics.
   / Pulled the trigger on a new RTV X 1100 CAMO #20
Nice looking setup. Are the springs cranked up in the front? Might help with the sag from lifting your plow this winter. Dialing in the springs and adding enough ballast will help with getting enough traction to get the job done. With my Boss V plow I've found 500 lbs in the bed to be about perfect on my Gator
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
UNUSED JCT 2 PRONG BALE SPEAR (A57193)
UNUSED JCT 2 PRONG...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
(2) USED 7000 LB AXLES W/ BRAKES (A57192)
(2) USED 7000 LB...
148in Roll up Door (A55852)
148in Roll up Door...
250ft Roll of Copper-Clad Aluminum Building Wire (A55852)
250ft Roll of...
