Biggest battery for L3800?
/ Biggest battery for L3800? #1
Rail Dawg
What's the biggest battery you were able to put into an L3800?
Thanks!
Chuck
/ Biggest battery for L3800? #2
I doubt many have had to change the battery yet. L3800 hasn't been out long enough to need a battery replaced?
/ Biggest battery for L3800? #3
I guess I'm among the 'lucky' ones? My L3400 went out @ 3 years, <100 hours. I replaced it with an Interstate of the same size as the original though.
Like Bluegill2 said, your battery has to be fairly new; a prorated exchange should be in order.
Good points. 3 years in the Texas heat and I get concerned. The original battery isn't leaking and it's still starting the tractor just fine...
Maybe I'll wait.
Thanks!
Chuck
/ Biggest battery for L3800? #5
Here is a chart that list all the battery groups and their size. You could do some measuring to figure out how big you can go. I would go with the battery with the most CCA. When the batterys go in my tractors I am going to replace them with a AGM battery.
/ Biggest battery for L3800? #6
The original Kubota OEM battery in my old B7500DT was still cranking it fine after over 8 years. I know batteries can go south whenever they feel like it, but some of them last a good long while.
/ Biggest battery for L3800? #7
I have the smaller L2800HST, but it is coming up on 7 years on the original battery.
/ Biggest battery for L3800? #8
I wouldn't worry about a larger battery!
/ Biggest battery for L3800? #10
Same here , mines a L3400 DT 2007 W/original battery.
Yeah, I feel like I was born under a dark star... Mine died right after 3 years. :-( If there's a "bad" battery out there to be had, I'll end up getting that one. I've bought 7 this year, and getting close to needing 12 more for our two golf carts.
PS The carts are used for farm work - not golfing.
Brady 12ft. Field Cultivator (A65640)
Brady 12ft. Field...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
White Metal Roof Vents (A64194)
White Metal Roof...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
Wooden Wagon Wheel Rocking Chair (A64127)
Wooden Wagon Wheel...
Ford Tailgate Sign (A64127)
Ford Tailgate Sign...
