3-Point Hitch DK55 3 point lift will not lower.
   / DK55 3 point lift will not lower. #11
It looks like there are several ways the lowering knob can be loose from the MLS valve with no actual problem in the actual MLS valve. See:
I'd start bu ensuring the actual knob is locked to the shaft. If that's OK, it's time to pull the seat (it's heavy).
Well pulled seat and panel cover off, everything looks good as far as the MLS and lowering speed adjustment is concerned. Everything is dusty but no fluid leaks visible and everything on the draft and lift assembly looks and feels tight (no missing bolts or nuts anywhere) Any more suggestions?
   / DK55 3 point lift will not lower. #13
Try smacking the MLS valve lightly with a plastic faced hammer or dead blow hammer to see if there is a stuck passageway/spring/ball. If that doesn't work you could crack open the hydraulic fittings enough to let the pressure down and hopefully get the hog on the ground. This could also prove the valve's the problem, or not. Exercise caution regardless of the route you take. BTW, full disclosure; I can't say whether what I suggested above will work or not with any certainty, buy short of disassembling the MLS valve to seek out possible issues with it, this is what I might do if I were you.
You could still search for prior MLS valve issues in the Kioti forum; I'm sure I've read about at least one failure/resolution thread in the past.:confused3:
Well Coyote Machine you came up with a FIX!! 3rd tap with a dead blow hammer worked!!! Each one was harder than the one B4. I had put a hydraulic jack under the BH and when it fell it was about 1". The system worked repeatedly after the tap! I know something had to have caused it but I still have no clue yet what it is.
I want to Thank everyone for their contribution to this thread! I will probably go ahead and do a early fluid and filter change out soon. Thanks again ALL.
   / DK55 3 point lift will not lower. #15
Good show Captain!
   / DK55 3 point lift will not lower. #16
Sweet! Glad it worked out for you!:drink: Hopefully whatever lodged in the valve is now heading to the filters. Keep us posted as to whether it keeps working for you over time.:thumbsup:
Good show Captain!
Hey thanks! It's good to be King.:laughing:
2006 Ford F-650 Terex Hi-Ranger TL37P 37ft. Bucket Truck (A55852)
2006 Ford F-650...
2014 MGB BLENDER (A55745)
2014 MGB BLENDER...
2013 freightliner Altec D2050-TR Derrick Digger Truck (A52377)
2013 freightliner...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
