If the HST dipstick on your BX looks like this....
   / If the HST dipstick on your BX looks like this.... #1
brinet
then your HST fan probably looks like this....
   / If the HST dipstick on your BX looks like this.... #2
Both invalid attachments
   / If the HST dipstick on your BX looks like this.... #3
Woah!
Everything works OK?
Everything seems to be working. Not my tractor and it's a mystery how it happened.
My question is "What is the melting point of the dipstick?"
This is why I'm working on a HST temp gauge and warning light.
   / If the HST dipstick on your BX looks like this.... #7
It's hard to tell from your pic, but I doubt the dipstick handle melted.
The fix might be to install a new fan and a skid plate; there is one already available; others here can tell you where to get one.
A temp gauge could be made from a oil temp probe installed into the HST oil pan, which would monitor and display the HST oil temp on a constant basis, and could be used to establish an acceptable operating range for the fluid.
It might even be able to be done through the dipstick port via a temp thermo-probe from a multimeter, without having to remove and drill a hole in the HST pan.
   / If the HST dipstick on your BX looks like this.... #8
I would bet that an in line sensor would be pretty easy to do, and they might have one from a different machine. Personally I always hated idiot lights, I want a needle with a background of numbers.
The dipstick did melt. Owner is replacing fan, changing fluid and filter today. I'll update with any new findings after the repair.
   / If the HST dipstick on your BX looks like this.... #10
So the dipstick is plastic, in addition to the dipstick handle? What about a skid plate?
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52128)
2015 Ottawa Yard...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52128)
2023 New Holland...
