Paint compatability
/ Paint compatability #1
bones66
BlueGrass State
MF-230
I had my tractor weight bar welded recently as the strain over the years had began to take it's toll. To keep the welded areas from rusting I planned to brush on some Rustoleum primer followed by a coat or two flat black Rustoleum paint. Then after I applying the primer I remembered having a quart of Massey Ferguson Grey. Thinking this would look a little better and since I already have it wouldn't cost me anything I dug it out. The Rustoleum primer is oil based and the Massey Ferguson paint say's it's a "High Performance Enamel". Are these two compatible?
/ Paint compatability #2
Why not test it on another piece. I always test different brands of paint to be sure.
Thought maybe someone had already been there done that and save me some time. If the test show some immediate compatibility problems I could handle that but don't want it to hurt long term durability or something that won't surface for a period of time. Hope my jabber make sense as I'm trying to do this from a smart phone an it's difficult to read! Sign of the times I suppose. Thanks
/ Paint compatability #4
Without knowing exactly what type of paint the primer or your grey top coat will be, I will give you my 2 cents. Both the primer and flat black are likely acrylic enamels. If the grey doesn't require an activator/catalyst, it is also probably a compatible acrylic enamel. Even if it's the cheaper alkyd enamel, it will adhere and last OK. Alkyds typically just oxidize and fade quicker. Lacquers can be a problem to cover. Although you used flat, I would also rough up the surface a little with 200 grit wet/dry sandpaper. You can also check the MSDS to find the types of paints but I think you are good to go. Good Luck.
/ Paint compatability #5
I would think both would work fine together, neither being a hi tec product. or exotic.
/ Paint compatability #6
They are likely alkyd, aka, industrial enamels.
The entire Rustoleum line of brushable paint is industrial enamel.
Farmer paint is usually low budget, low tec stuff.
/ Paint compatability #7
Tsquared answered the question correctly. They will work together just fine. Stay away from lacquer paint. It will lift most of the base coats. Chalking will be the biggest issue down the road. Instead of sand paper, use a fine scuf pad. They work great in corners. Wipe down with a good wax and grease remover. Tack rag it, and then the fun part! Painting
Thanks fellows for the replies. Now you guys know what happened? Nicely painted weight rack............cruddy looking weights so I had to fix that problem. .........Now all that bright factory color on front make that front grill and grill frame look really bad but it has to stop!
2007 INTERNATIONAL 7600 6X4 T/A GARBAGE TRUCK (A66091)
2007 INTERNATIONAL...
2007 KENWORTH W900 (A67714)
2007 KENWORTH W900...
More info coming soon (A64557)
More info coming...
1999 INTERNATIONAL 2674 T/A DUMP TRUCK (A67714)
1999 INTERNATIONAL...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
20' CONNEX BOX (A67714)
20' CONNEX BOX...
