Advice on welding and shortning a roll bar with canopy
   / Advice on welding and shortning a roll bar with canopy #11
Never done this before - but any chance you could cut off what you need at the bottom where it is bracketed to the mini after removing the brackets, then weld the brackets back on? For the small amount of welding you might even take it to a shop and have it done professionally or have the welds certified to keep the ROPS' integrity and loose the possibility of liability. Just a thought. Keep us posted however you go and remember - we love pictures.
   / Advice on welding and shortning a roll bar with canopy #12
The ROPS is a certified safety device. Any professional welding shop that would shorten and re weld your ROPS would assume liability should your tractor roll over and have the ROPS fail possibly injuring the operator or worse. Many here have done their own. I'm doubtful you will find a shop that wants that liability.
   / Advice on welding and shortning a roll bar with canopy #13
I reckon you told me.....
good thought, I should consider that im sure..thanks. I assumed that a 'welding' shop would not like to take on the welding..'
   / Advice on welding and shortning a roll bar with canopy #15
Only trying to point out some facts.
However, there are many good welders here that have modified their own ROPS. If I had that problem I would do my own since I confident in my welding skills but wouldn't weld anyone else's.
   / Advice on welding and shortning a roll bar with canopy #16
Setting aside the ROPS cert issue, the highest stress (bending) should you roll over will likely be at the base connection to your tractor. Thus you would be messing with the most critical area of the ROPS.
   / Advice on welding and shortning a roll bar with canopy #17
How about doing away with the ROPS and going whole-hog on a roll cage from a super stock pulling rig? :)
Sent from my LGL35G using TractorByNet
   / Advice on welding and shortning a roll bar with canopy #18
Just a different thought. What if you just cut it off at the height you want and then weld a new cross piece in? You would probably want to weld some sort of cap onto the end to keep it sealed. I think it would be a lot easier to weld.
Doug in SW IA
   / Advice on welding and shortning a roll bar with canopy #19
I'm on board with this idea! :licking:
   / Advice on welding and shortning a roll bar with canopy #20
Doug in SW IA
I think you should preserve the curved section. Welding a cross piece that causes a corner will be a stress concentration and surely be where it fails. :2cents:
PALLET OF ALUMINUM PARTS (A57192)
PALLET OF ALUMINUM...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A58214)
2020 INTERNATIONAL...
2014 Kawasaki Mule 600 Utility Dump Cart (A55973)
2014 Kawasaki Mule...
2020 DRAGON ESP...
