jd214 runs well for about 15 min then runs very rough.
   / jd214 runs well for about 15 min then runs very rough. #1
jd214
Member
DRYDEN ONTARIO,CAN
2-214-JOHN DEERE
my 214 starts fine runs for about 10-20 mins, then starts to run rough, motor shakes like craze, sits for about half hours , starts again fine does same thing over and over. parts i have changed, coil, condenser, points, new carb, some wiring, seat switch, fuel cap, new muffler, drain valve on fuel tank. plse help, getting to end of the rope. plse help. thnx again.
   / jd214 runs well for about 15 min then runs very rough. #2
Check the fuel pump and the fuel filter. Sounds like a classic fuel delivery issue to me ----------
will do thnx
brucwatlam, one question, after it runs awhile it seems to load up, if you give it full throttle, it smokes and runs terrible??
   / jd214 runs well for about 15 min then runs very rough. #5
That starts to sound like and ignition failure and unburned fuel ----------- Maybe somebody that knows your model better than I do will come along with some help.
   / jd214 runs well for about 15 min then runs very rough. #6
Possible ignition coil or component failure after operating temperature is reached. Have used a heat gun (industrial/military strength hair dryer) to induce temperature related component failures in my past life.
   / jd214 runs well for about 15 min then runs very rough. #7
One thing at a time ---- make sure that the fuel pump/fuel filter are healthy before you do anything else.
   / jd214 runs well for about 15 min then runs very rough. #8
A fuel supply or quality issue would exhibit itself right after starting. The complaint here is only when operating temperature of all components has been reached.
Dumping fuel first is reccomended and fundamental.
   / jd214 runs well for about 15 min then runs very rough. #9
Classic pinhole in gascap plugged. loosen gascap to confirm
2014 Ford Explorer SUV (A53424)
2014 Ford Explorer...
2015 CASE 580N (A47477)
2015 CASE 580N...
2012 NEW HOLLAND BOOMER 3045 COMPACT TRACTOR WITH 250TL LOADER (TRANSMISSION ISSUES) (A55301)
2012 NEW HOLLAND...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
Hr:8,875 vin:316000649 (A53421)
Hr:8,875...
