What happens if you regularly shutdown a diesel engine with the throttle wide open?
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #11
A motor liquid or air cooled gets the hottest the minute it is cut off. It stops bringing in cold air. If you are at full throttle that heat is being dissipated in part by air coming through the intake when you stop bringing in that air and stop the cooling process without throttle down to help the engine release the heat you decrease the life of the engine by making it sit there and absorb all that heat. Also if you cut the motor off and suddenly stop the crank shaft while spinning at a high rpm it will remove a small area of bearing surface. One much larger than if stopped at a low rpm. Think about coming to a complete stop from 5 mph in your car or 60 to a complete stop in one foot.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #12
Pretty much the entire engine is designed to work with the loads in the opposite direction than what happens when you shut down at high idle.
One of the worst things you can do to anything with a timing chain, or timing gear, is shut it off with the engine at high rpm....friction wants to stop the pistons, but everything else wants to keep going (relatively far less friction) and that's how you throw a timing chain, or strip a gear.
If you've been running the engine at a normal work load for a while, and suddenly shut down, the other thing that happens is that the coolant stops circulating, and the excess heat has nowhere to go, so it dramatically raises engine internal temperatures.
Giving the system just a little time to stabilize under low idle before shutdown will avoid all of these, and probably other, problems.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #13
Strange question, not trying to sound rude, just a why ask why type of question.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #14
Good question Happy. I have always treated machines like horses - walk the last mile home, do not gallop. In an emergency make sure somebody else cools off the horse.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #15
If it was my gear the offender would get a swarm of wasps in their ear. Why should they wreck my gear? Also even if it was not my gear I would have a blunt word with them. That sort of machine abuse is very unprofessional.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #16
I do agree with what's been said but, in construction, you see it a lot. Guy jumps on roller, revs it to max, uses it for 5 minutes; cuts it off. Mostly out of not knowing better, some from not caring. I've always heard to idle it down, and wait 10 seconds; no idea if that's a good about of time or not.
Can anyone point to actual failures that appear to relate to frequent shutdowns at full throttle/high idle (i.e. the engine going from about 3000 RPM with the hand throttle full forward)? What fails specifically? Turbochargers?
Thanks for all the replies.
Not quite sure what you mean by this. I'd just like to be able to say, here is why no one should be doing this, and if we continue to do so, these problems will likely crop up.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #19
With all due respect, perhaps you should read all the good and valuable comments on why not to do this, in response to your Thread. You are asking why you should climb down a ladder instead of jumping off the top rung because it's a quicker way to arrive at the bottom. Personally I think you are smarter than that.
   / What happens if you regularly shutdown a diesel engine with the throttle wide open? #20
I think its a good question. However I think it addresses another subject of habits. Habits are hard to change but I think the poster is asking if it doesnt cause harm than why question why its done.
I view it part as similiar to why I leave the bucket on the ground when not running it. But Ive learned from here that it is good for the seals to be in pressure. So there are many factors involved.I still prefere to leave my hydraulics in a 'relaxed' state.
An example is lawn mowers of today ,they start on a high RPM I believe this is detrimental. But its how it is.Even my ride on ,to choke it you have to go through the throttle. and it chokes and starts on high RPM untill i can get the throttle back down to idle.
So i would guess in the long run if no turbo, it wouldnt be an issue which would be dependant on how many time and how many years.
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
20704 (A55853)
20704 (A55853)
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
Portable Restroom (A54865)
Portable Restroom...
LandHonor PTO Skid Steer Attachment (A56857)
LandHonor PTO Skid...
