cartod
Looks like it has great potential. Build a good dam.![]()
A dam good dam!
A dam good dam!![]()
There is nothing of value below the dam that would create a liable situation, also there is a reason you don't need a permit under an acre, it's just not enough water to do much damage.:laughing:
Seriously, and I bet you have thought about it already, but for the sake of liability management it's good to consider what is below/beyond that ravine, or could be in 20 years, where the wall of water would run if the dam failed. Are you thinking of digging down in the area where the brush is piled? That would help limit the amount of water that would leave in a failure situation.
They recommend I remove most of the stumps as they can make the water toxic over time. I know, I know, they leave the whole tree in some of the big lakes but I have heard this from more than one reputable pond builder.I think I would just leave the stumps as habitat for the fish as long as they were not in the way of digging.
Will do Brandi! Yep, the stumps that are there now have a continuous stream running under them. Even in the driest summers there was water flow under the tree roots.When you get the stumps out, cover any root holes with a good thickness of clay and pack it down. Like wise on the dam and dam core trench........pack it all down good. Then pack it some more. Any root left is a potential leak.
hugs, Brandi
Thanks Eddie. I have two 8" pipes that will be filling the pond. The pipes carry runoff from surrounding hills. I was more concerned about not having enough water....So I guess Ill just have to wait and see. My plan is to make the back of the dam gradual enough to mow, and the emergency spillway will be packed with rip rap and will hopefully handle all the water Mother Nature throws at it. I will post photos as soon as the excavating begins. Water will be about 25' deep at the dam.That's a real nice setting that you have there. The house looks amazing and the pond will only make it look that much nicer!!!!
I wouldn't worry about those stumps too much if they are going to be in the water and not part of the dam. You want to dame to be as free from anything organic as possible. No top soil in it and no roots or branches that will decay over time. From the picture, it looks like you are on the side of a hill and the water will be coming down the hill to fill the pond. How much hill is above the pond and is there any concern of too much water coming down and overwhelming your spillway?
The number one reason a dam fails is water running over it. The water erodes the dirt and it just keeps working it's way down until all the water is gone and you have a big gap in your dam. I've seen it happen about a dozen times around here and I'm sure I'll see it again. A big rain will put a lot of water in there quickly, you need to be able to get it out of there just as quickly once full.
Another concern is how tall will it be and how steep will the dirt be on the dam? You never want trees growing on your dam because their roots will tunnel through the dam and over time create a path for water to travel through the dirt in your dam. Grass that is maintained and mowed a couple times a year is a great way to protect your dam from erosion, which means it has to have a slope that you can mow. Rock, riprap and gravel are even better, but very expensive since it has to cover a lot of area and be thick enough to protect the dirt below it from erosion.
Eddie
