Rotary Cutter PTO Driveline Parts
   / PTO Driveline Parts #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
Looking for the plastic retaining ring 'bearing' for a Comer Industries T50 Series 4 PTO driveline. It goes on my Bush Hog 285 rotary cutter.
You hear of and see videos of people preaching and preaching on safety about "Keep that PTO shaft guarded!" "It's very unsafe to operate without it!"
I agree with this 100%. I have no problem what so ever keeping the shaft guarded, greased, maintained, etc..
But what I DO have a problem with is nobody can seem to tell you where to find replacement parts!! So dangerous and unsafe, yet so difficult to acquire new guards or parts for the guards.
Anybody else notice this? PTO shafts and related parts are things that should NOT have to be 'hunted down'.
   / PTO Driveline Parts #2
Any dealer with an account with A&I should be able to order them. They would be cheaper than buying from a bush hog dealer.
I looked on the A&I website and it seems as they may be selling to the public now? Not sure. But I would still have to know the correct part and part number to order.
   / PTO Driveline Parts #4
Allpartsstore is A&I's public site. A good dealer can tell you what you need, the information you post should be enough to ID the shield bearing.
I think that the Comer number for the inside shield bearing is 180015008 and the outer shield bearing 180015009.
   / PTO Driveline Parts #5
I would give Messick's a call. I am sure they can either provide the part or point you in the right direction.
Allpartsstore is A&I's public site. A good dealer can tell you what you need, the information you post should be enough to ID the shield bearing. I think that the Comer number for the inside shield bearing is 180015008 and the outer shield bearing 180015009.
These are the 2 part numbers I came up with also. Thanks.
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
Kohler Generator (A50322)
Kohler Generator...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
71056 (A49346)
71056 (A49346)
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
