What implement should I get for renovating old pasture?
   / What implement should I get for renovating old pasture? #1
KiotiJason
Gembrook Victoria Australia
Kioti DS3510 and 2 x Fordson Power Majors
Hi Guys,
I've got a 10 acre paddock that is very compacted so the grass is a bit patchy etc. I have a bog and bush plow which I could use to completely plow the however I'd like to try and improve the areation without doing that and hopefully improve the pasture without going back to scratch. After recently buying my Kioti I don't have a lot of funds and I'm only on 50 acres so I need to get something versatile that I can continue to use to improve the pasture without distroying it. My initial thoughts was a ripper or scarfer. Over here there isn't any option to hire attachments like this. Also I've used an aerator on other a paddocks (I should have purchased it) however I think I need to go deeper first. I've got the fordson I could use for the heavier work however I've grown accustomed to the comforts of the Kioti. I dont plan on keeping the Fordson for much longer so I need to think about what I could continue to use with the Kioti DS3510. So the plan is to get The deep aeration without distroying the pasture thats there. ( I will top dress ith some seed once I've finished though)
Any advice would be appriciated. The soil is clay based with very fine granite, good drainage etc just very compacted.
   / What implement should I get for renovating old pasture? #2
Hi Guys,
I just bought field cultivator/ripper.Go to everything attachments and key in fred cain field cultivator.I looked at fred cain but ended up buying bush hog brand instead from my local dealer.
Have you managed to try it out yet? My tractors only 35hp so I guess I'd need to get something that it will pull. Can I ask what the purpose that you bought it for?
Thanks for your help!
   / What implement should I get for renovating old pasture? #4
No I have not tried it yet.I bought it to put in deer food plots.I would think a smaller 5 shank field cultivator would fit your needs.
SAKAI SMOOTH DRUM ROLLER (A52709)
SAKAI SMOOTH DRUM...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
2014 FOREST RIVER WILDWOOD RV TRAILER (A58214)
2014 FOREST RIVER...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
